Lets have a big Ass cruise to the gong! 14/12/02 MEETING SPOT CHANGED!
I'll come if I can get the day off work.
Anyone on the northern beaches want to lead me down to the gong again?
I might follow bigvis down there unless it turns out the blind is leading the blind (not unlike following MRTRBO on the last gong trip
:D
Another burger King or whatever meet?
Mark
  • Replies 122
Sure MRK25T, no probs. Do you fellows think it will be laet. I have a gig back on the northern beaches at about 6:30, hiope I can still come. Another good idea is the burger king run on the beaches, last one looked and sounded like fun...count me in
Danny... u going on this cruise?
Also Moanie.... i would mind having a look at your car.... might have to get u to take me for a spin if thats kewl.... im trying to choose a new turbo and wouldnt mind seeing how yours goes with the 2530......
Certainly looks awesome.
Nick
Originally posted by brendanf
I'll be there - I'm gonna :Owned:  yas all !!
Mark - you can follow me  - Let's meet up at BK again !!!!
Def have my car back by then
B
aiiiiight, i *might* be there too - but we'll see.
Originally posted by MissS13
No can do for me... I'm working
Have a good time all. :(
sheeeesh - if its not me working, its you working!
coming to the track day?
Originally posted by RONIN
Would anyone be kind enough to let me jump in with them???
I'd like to take some photo's :( I live in Turramurra BTW :D
Ronin, I can possibly pick you up - Will know closer to the date. I'll let u known on this thread man.
Nick
Not this time mate i got a wedding to go too, i was suppose to go to RUMBA but the wedding will make up for it- lets see if me and my bro can beat our scotch & coke JUG record lol
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
