I finally get my first beloved R33 GTS-T this Sunday 20/02/2005!!
I've researched this for nearly 2 years and have finally bought a 1997 model in black with 43,000km, a sports muffler and a set of ADVAN 17's. Other than that it's totally stock. I have my ideas on what I would like do to modify it, but,
WHAT DO YOU GUYS RECOMMEND???
Keep in mind its a daily driver and I'm not interested in allout power for the dragstrip.
I was thinking:
1. Power FC
2. FMIC
3. EXHAUST
4. POD FILTER
5. DUAL STAGE BOOST
6. NEW TURBO
What order first??
https://www.sau.com.au/forums/topic/64867-i-get-it-on-sunday-first-mods/
congratulations!! 2 years...holy crap..no wonder you're excited :)
and I agree with above...def zorst and filter first...let her breathe..
I was thinking that if i tuned a power fc while standard first it would improve fuel economy and give it extra power. then i could tune it whenever i add more mods.
THANKS TO EVERYBODY FOR HELPING ME OUT!!! :D
This is what order I did and I recently(2 days ago) got 208.2rwkw at the wheels on 9.6psi.
3 zorst
4 pod with CAI box
1 power fc and tune
2 front mount
5 EBC & tuned. ( I did 2 & 5 together and tuning 2 days ago)
This is with a stock turbo, clutch, AFM, shocks/suspension/etc...
If you decide to go with larger turbo you should strongly consider the other mods aswell.
I will be doing my handling, braking, clutch, AFM and also cams and cam gear before upgrading my turbo.
After this I should reach my goal of 250rwkw :)
good luck :P
If you're going for a daily driver, and not on the strip, do you really need the new turbo?
I would mainly want to upgrade to a new turbo for a stronger, more reliable ball bearing turbo with steel impellers, I've heard that the standards cant be pushed safely, thats all.
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
    • Yeah the rule of thumb with an LS is 7psi per 1000rpm. That is decidedly not enough at 6800rpm. I mainly looked for the scenarios where knock started to be picked up and it was later in the session when things were hotter, and oil was thinner, and the pressure was lower than it should be. (i.e very horrible). I am hoping with thicker oil (I was running Penrite ten tenths 10-40, the manual specifies 10-30) that does not leak that it's much improved at that time!!! I am using Project Mu Club Racer CR pads. I'm also using the Project Mu 335C fluid. The symptoms imply that it was fluid that boiled, but no bubbles seemed pretty weird to me when I bled it today. I want to try Castrol SRF as it has a much higher wet temp but, well, I have new Project Mu fluid lol... so I should at least use that. The pedal on track was really noticable. It went from basically normal feeling to instantly near-floor. The car did pull up as before, it was just very much nearly at the floor before the brakes engaged. At that point I pretty much decided the day was very done, it did *kinda* come back during that very slow cooldown lap into the pits. Felt perfectly fine driving home.
    • f**king around with the bro
