there is an even cheaper option which will work extremely well. find a Norgren Industries (pneumatics company) outlet near you and go there. purchase a pressure relief valve and a pressure regulater valve. make sure you get the screw-in adjustable ones! they come with 7bar springs in them standard, you will need two .7bar springs. also get four barbed hose fittings to fit your wastegate hose.
all up it should cost you about 80-90 bucks.
install them in series (with the new springs!) in the wastegate-compressor housing feed line, with the pressure relief valve first and the pressure regulater valve second in order of pressurised airflow to the wastegate.
what will happen is that at any boost below, say, 12psi (they are completely adjustable) the pressure relief valve will not let ANY air through at all. this eliminates ALL wastegate creep. you will get full boost as fast as possible with your setup. at 12psi the relief valve will open and let air through to the regulator valve.
the regulator valve will hold the air coming to it at exactly, say, 13psi. this means your wastegate will open at 13 psi. the system will then instantly reach an equilibrium at your desired boost level of 13 psi and will open/close the wastegate as desired to maintain that boost level. if boost falls below 13psi, the wastegate will instantly close fully until that level is reached again.
so there you go, a fail-safe and excellent cheap anti-creep, anti-spike boost control setup. both the valves are fully adjustable and have "lock-down" ability once you set them. because they are built to handle 7+bar of air pressures (100+psi!) they are extremely accurate and fail-safe. give it a go and see if you don't like it, hell it's even cheaper than a stupid bleed-valve from turbosmart or similar.
https://www.sau.com.au/forums/topic/64895-boost-controller/#findComment-1214118
Yeah - that is a good setup from autospeed, but it's damn risky not telling the person to be very careful with adjusting the knobs!!! something for yo uto keep in mind...
This is best set up (as are all boost controllers) on a dyno. Another problem with the above set up, is once it is set, you can't really lean out the window and adjust the setting for a wet road, or a 'hit' of boost. How does it go with a factory EBC???
https://www.sau.com.au/forums/topic/64895-boost-controller/#findComment-1214136
If you can read, interpret instructions and solder OK then the Jaycar Intelligent Boost Controller works very well and has some quite unique advantages. Have a read in the Stagea section for the results.
I have a throttle pedal on my car for that purpose.
https://www.sau.com.au/forums/topic/64895-boost-controller/#findComment-1214261
Is the Norgren setup really that good though? I mean at the moment i'm just using a dual-stage bleed valve (unsure of brand but it's name brand) but my boost isn't holding at what it's set at (12-13psi). When I ask local tuners/mechanics I get the typical "it is because you have a stock ecu" or "thats a stock turbo for ya" etc etc when they don't even know what components I have.
Do you think if I changed to this Norgren setup it would fix the problem below (set to 12 but only holding 9psi regardless of if I set it at 10 or even 13psi)... ?
https://www.sau.com.au/forums/topic/64895-boost-controller/#findComment-1214293
I have a hiperboost control i will sell if your interested. Bought it as hoped the wastegate control valve would help my boost drop at high revs however now realise the turbo is running out of puff. Works quiet well otherwise. Keeping my PFC boost controller.
You can have it for half price posted for $200. Read about it here.
http://www.hiperboost.com/
https://www.sau.com.au/forums/topic/64895-boost-controller/#findComment-1215161
If that is a standard turbo you may well be running out of airflow, insufficient airlfow to hold the boost. If that is the case, it doesn't mastter what boost controller you fit.:/
https://www.sau.com.au/forums/topic/64895-boost-controller/#findComment-1215320
* Can I swap just the AFM from a S2 -> Z32 without needing to change anything else? (ie; requiring aftermarket ECU etc)
* Is their a way that I can check if my S2 stock AFM is maxing out without removing/modifying anything?
https://www.sau.com.au/forums/topic/64895-boost-controller/#findComment-1215495
Benm
the Norgren controller will not stop your std turb running outta puff.
Get a R32 Acturator (10psi)and the Norgren setup, at least the creep will be gone and the controller will have some of the load taken away from it.
Mine makes full boost (12psi) by 26 - 2700rpm. It does however drop of to around 9psi even with the R32 Acturator.
https://www.sau.com.au/forums/topic/64895-boost-controller/#findComment-1215558
Hi Guys
I found on the nissansilvia.com site that they have the Blitz SBC iD III for the AMAZING price of $590 delivered!!!! That is Fu*king awesome, considering I paid $700 for mine 2 weeks ago!!!
The silvia guys have much more/better group buys!!! what is going on?!?!?! I'm getting my PFC+HC for $1050 delivered from there as well!!!!
https://www.sau.com.au/forums/topic/64895-boost-controller/#findComment-1216642
Hey R33vit. You say you make full boost by 2600-2700 rpm. What gear is that in - is that in 4th.
I find in my car with full 3 inch turbo back exhaust I get full 7psi of boost at about 2900rpm in 1st and 2nd...and by just over 2000rpm in 4th or 5th gear.
I was hoping to just fit the Norgren relief valve with check valve to get increased response. Would you get full 7psi by 2500rpm in 1st or 2nd with the Norgren anti creep setup?
Is there a decent gain at part to half throttle etc?
Maybe I'll start a new thread...
Thanks
https://www.sau.com.au/forums/topic/64895-boost-controller/#findComment-1219182
i have been using my GReddy Profec Bspec II for a while now, i like it. seems to do the job.
i have never used any other elec boost control. so i cant really compare it to much. but i was using a bunnings style bleed valve before that and you cant really compare :(
https://www.sau.com.au/forums/topic/64895-boost-controller/#findComment-1222575
i have an AVCR but i intend on chaning it with an HKS EVC4. I heard that the Blitz and the HKS ones are better. But i believe its marginal. If you want a screen thingy, go the AVCR (or HKS EVC5 but thats more expensive).
https://www.sau.com.au/forums/topic/64895-boost-controller/#findComment-1222597
ive got the hks evc3 (old school style, inasnt has same but with ext gate) in r33 series 2 with stocker turbo. its a simple set and forget device, has support to learn the boost curve and wastegate open pressure. holds boost perfectly and its only ever overboosted once and it beeps when it happens. nice and cheap and provides a good reliable solution
https://www.sau.com.au/forums/topic/64895-boost-controller/#findComment-1223412
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
