Silly thread this one, and the dozens like it from yesteryear.
My only experience in a R33 gtst is with 10psi boost and an exhaust you can run easy 13.8's on factory sized rubber, without touching the ecu. I had about 100kgs of work gear in the boot too.
I don't see many similar modded WRX's of the 1999 vintage doing that, in fact I've never seen one do it. This includes the STi version of that era. I am talking a real drag strip not some magazine test with a g-tech. Doesn't mean to say it hasn't been done I just haven't seen one myself.
Having said that... many owners of skylines and WRX's alike suffer from an inabillity to drive them well, making the argument a kind of which cars are more likely driven by people who can't really race discussion.
In this case I'd say a dead heat.
  • Replies 75
Dave
I know of many stockish rexes runing better than 13.8
My best mates evo 4 wrx(MY00) - with turbo back exhaust and stand boost ran a 13.4 at kwinana.
Dan
I have heard similar Dan just never seen it myself. I believe you of course.
I think talk is cheap about this kind of thing, for the people concerned they should take it to the race track and find out.
Easy isn't it. :cheers:
Now I wonder which one is faster in reverse?
GTST, the only classic model rexes that were 1300 kg were the wagons, 99-00 sedans were 1270, 97-98 were closer to 1230.
My 2000 model ran 13.7 stock, so they are pretty capable. But yeah, some people don't know how to drive too.
And to all you guys, 13 pound is stock boost in a rex. They are a lower compression motor and can handle more boost, but at the cost of more lag.
my experience,
My car 97 gts25t HAD approx 200rwkw wif Fmic/pod/exhaust t3/t4 turbo ecu 1bar boost (not holding boost drops to 12psi approaching red)
mates car 98 wrx vf22/28 i think 1bar boost (holding well no drop in boost all the way to redline, exhaust/pod ecu BUT no FMIC BUT has water spray).
ANYWAYZ.
both off the lights a right turn into a mainroad waiting for each other then flooring it in Second, both having one passenger, head to head up to END of THIRD for me which is 150km/h and still HEAD TO HEAD then we called it quits....
BUT iF off the spot i think i would lose due to traction problem and him having 4wd.
i personally think WRX a quicker..
(THEY CERTAINLY FEEL ALOT QUICKER ALOT MORE G-FORCE!~, BUT when you line them up very close)
Both are pretty even cars, it depends on mods.
WRX has the AWD advantage, so theoretically should win stock, BUT, few
WRX owners are willing to all out launch, given the sound reputation of WRX gearboxes :bs!:
As performance is similar, it probably comes down to looks. In my opinion, u can't beat the Skyline tail lights. Alternatively, get a GTR ;)
a r33 gts-t is cheaper then a 99 wrx and goes faster and looks better... end of story.
are you serious? its cheaper cos its older. i would have to agree with slow13dude in that the STOCK wrx looks better than the STOCK gts-t. performance wise, i would say wrx would be quicker.
Thizzle: how about you drive around and look for, lets say a Rigoli wrx, and see how well your 'hks' goes!
wrx may get the 1st to 2nd gear ...then see yah rexxy .. ive been in that situation where i was the passenger of the wrx against my cousins r33 ...then vice versa ..
race 1
note: 1997 wrx 555 with mods were cat back exhaust, 17inch gold rims
note: r33 1993 only mods hks filter, still running standard boost and stock wheels
winner: r33 by 3rd gear all the way .. but wrx won 1st to 2nd gear thanks to the 4wd system ...as the r33 struggled to get traction.
race 2 (same cars but with further mods)
555 wrx with: 15psi boost, uni filter.
r33 with: full turbo back 3inch exhaust, 19inch wheels, 10 psi boost.
winner: r33 blitz the rexy on 1st gear (thanks to the 19inch wheels for traction)
bear in mind that both drivers are experienced street racers,... and later that week my cousins r33 raced against an 2001 STi with full exhaust and filter only ..and the winner is r33!!
as long as the r33 has its traction .... kapow! bye bye rexy .. this race was done at the brisbane hwy from gold coast to yatala.... queenslander's yah know what im talkin about!!
Street racing is dangerous.. but its so much fun.  Dont get caught or your gonna pay REAL hard by those little blue and red boys and gals.
tell me about it.. so muchhhhh fun and provides you with an adrenalin rush (better than sex, ..ahahha j/k) but can end up in some serious fatal accident nor heavy fines with your car being impounded.
its nice to do once in a while ...specially in qld hwy's ..but on sydney roads .. forget it! those coppers are everywhere ...unseen and forseen ..
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
