yes the persons name might be over ambitious and a tad stupid but u guys don't have to be such fkn assholes. answer his question ffs.
dude for 12k i would buy a mildly modded 180sx with SR20. dont get a CA. you wont get a 33 turbz for that money but may get a really poor condition non turbz.
seeya
How did you know my names Dick :confused:
$12,000 should get you a nice 180SX or R32.
Have you tried here? Not sure if there website is up to date but worth a look
www.autojapan.com.au
Cheers
Hey all,
im trying 2 find a skyline,180sx,silvia etc for the right price.
im located in tha perth metro area...scarboroghish.
must b manual and turbo.
if any1 can help itd b much appreciated.
i would much rather buy privatly than from a dealer, my dad was a car salsman and i no wat they do 2 prices!!!
anyways thanx
jarrad
well.
thanks for ur input mate evry1 that said sumthing constructive.
spell check? get bent u dick.
v8? go smoke sum more crack
Hey umm.. Pootie Tang,
Firstly, your saying V8 = Smoking Crack ? We all are civilized people we do not use illegal drugs.
Secondly, please do not tell dicks to get bent, it makes me feel sick.
Peace G,
Aiiggght
http://www.carsales.com.au
silvias ranging from 8-12k.
dunno if they turbo ot not.
edit : scratch that, go here http://www.skylinesaustralia.com/forums/sh...ead.php?t=65820
and buy that, problem solved. if he aint in wa, get it frieted over with the left over money.
    • So I actually had the cover off my car today, here is a (bad) pic of the setup. I have an oil cooler thermostat block, the temp sender is straight in there. The pressure sender has a short AN line to a T piece which is mounted (hopefully cable tied counts as mounted....) on the chassis. BTW every fitting you could ever imagine exists....just depends what they cost and how many you need. Raceworx AN adapters are here: https://raceworks.com.au/fittings/adapters/, I think you said you need BSPT to AN (https://raceworks.com.au/fittings/adapters/bsp/tapered/an-to-bspt-adapters/) and AN to NPT (https://raceworks.com.au/fittings/adapters/npt/) BTW, braided line is super simple to make. It looks intimidating, is not.
    • Perfect day for a pie, really needs a soft top in this weather though
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
