115 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
I'm thinking of going onto a low usage insurance policy, as in the last year I've just done 8000kms...
So, for those of you who use their car for daily purposes or weekend warriors, how many kays do you do a year?
You can use the poll if you'd like
:cheers:
When i used 2 drive my Skyline 2 work everyday i was racking up about 15,000kms per year.
Now i drive my shitbox 2 work most days & keep the liner mainly 4 weekend & short trips during the week & occasionally 2 work.
I am now on an 8,000kms per year policy ($90 something per month, can't complain) so i should be pretty safe with this, not 2 mention less wear & tear etc. also.
the skyline is our only car, so we rack up a few kays in it;
got it 67k, up to 105 now and ive had it for just two years :(
saddens me to see so many ks going on, but on the flip side, i get to drive it heaps, so im happy as well
25000kays in 6 months i am the winner (so Far)
I did 8000kay in just under 3 months :kick:
I guess it would depend how many kays you drive each week.. No idea if you take the skyline out on the weekends, and do the "hey look at me" posing laps ect. I was surprised at how many kays I was doing just driving around on the weekend.
i am a whore and so's my car :wassup:
Hey Ronin 09,
I was thinking the same thing. Ihave had my line 4 over a year and have only done just over 6000km.
Which insurance company were you looking at going with???
I got a quote from famous 4 $2000 for this kind of classic cover.
Brendan
hey brendan, what rating are you?
Shannons want about 2100 for rating one 8000km/year
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
