  • Replies 115
If anyone wants some nice trick alloy bonnet pins that sit flush or 1mm above the bonnet line then let me know. Saw some neat ones at the Motorsport show the other day, skyline_geoff bought some at the Trade Store, im getting mine next week for my new bonnet
I don't need any at this time, but I might in the near future :)
Can you get a business card or details of the distributor when you go get yours please?
Pics would be good too :)
Yhe i have the business card at home. They are actually in NSW, if Geoff sees this he may post some pics. The bottom half that gopes into you radiator support mount is the same as usual, but rather then a pin thru the boonet, you have an aluminium housing the size of a gum leaf that has a push type latch/door.
When you push the latch, it releases the pin and allows you to open the bonnet. To close you clip it back down and its all spring loaded. So sits all neat and flush on the bonnet. Could even be colour coded i guess. They are attached to the bonnet by approx 6 allean head cap screws.
They are advertised in Autosport Engineering and are trick units. Ill check, but im 99% sure they are FIA etc approved so a re well engineered and perfectly safe. When i get back to Melb from Adelaide ill post the details up in the Motorsport section of the forum
what does compression have to do with pinging?
The higher the compression you run, the lower the detonation threshold. i.e. The less boost you can run before you'll start running into detonation problems.
I have never heard ANY tuner who knows his conrod from his clutch say that they can't run more than 13.5psi boost with a stock engine because the compression is too high.
I ran 1.2 bar (17.5psi) on my old GTS-t (I didn't want to run more because it was my daily driver and I didn't want to push the engine too much) and it made 280rwkw. The new owner ran it upto 1.5 bar (21.5 psi) also on the stock engine, and stock compression.
13.5psi = too much? :confused: Sounds like tuner limitation, not compression limitation to me :Oops:
when it hit around 15psi i can hear it ping, thats got really nothing to do with the tuner, i wanted it to be very safe cause i used to use it as a day to day car but now its purely for racing and the od cruize. i got more mods to do soon so we will see.
Oops, Speed.
I guess neither of them would like me confusing the two. Its too late and i had way to much C++...
They don't mind. Both Speed and Wheels are owned by the same publisher. If you confused any of those with Hot4's, or FastFours there would be hell to pay :D lol
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
