  • Replies 297
Now that we've figured the push/pull, what clutch do you use with an R33 GTR box and an RB25DET? do we use a GTR clutch or a GTST clutch, or do they both fit?
Also on a happier note, my gearbox will be here in 4 weeks!!! time to get stuff organised!
If you have a R33 GTR gearbox then you will need to use a PULL type GTR clutch, as RB25det clutches are push type in R33 GTST, not sure about R34 GTT
It does not matter what engine you have, series 1 R33 or Series 2 Neo or Rb26, it does matter what GTR box you have. (hope that makes sense)
  • 3 weeks later...
Well i got my Master and Slave cylinder fresh from Nissan today, getting one step closer now. my gearbox is due to arrive in melbourne end of next week.
Did you end getting the GTR vac type or 34GTT type master cylinder
I got the R33 type master, as i'll be using an R33 clutch pedal with a little modification to fit. i spoke with my mechanic, he said there's no trouble matching the R33 GTR slave to the R33 GTST master, and he think he can mod the clutch pedal to fit.
all i'm waiting on now is my gearbox arriving then it's all stations go. i'll let everyone know how it goes, any problems i get and so on.
  • 4 weeks later...
Has anyone got any pictures of how they secured thier handbrake foot to the floorpan? Mine did have 6-7 welds, but the metal is really thin and the some of the welds didnt go through both pieces of metal, so now it has become dislodged. I have one screw just holding it there, but would like to know if I have to get it re-welded or will 10-15 tekscrews be fine/safe to hold it there? Also will they hit anything underneath the floorpan there, like gearbox.....?
Out on the turps mucking around with a mate, nothing serious though.
the console looks good, will be better once it's in my car though. thanks heaps. just waiting on the all important gearbox now before i start getting ready for not having a car for a few weeks
Shit happens ay :w00t: i can't wait to get things rolling aswell, just a couple of things to go, clutch and a few bits and pieces. Yeah then the problem of finding time, and most likely having to do without the car.
Has your gearbox arrived yet from Slidewize?
I received a email about my GTR front bar has arrived and have paided for the shipping to Brisbane
Should get it by the end of this week.
I have found a late R32 gtr box (push type) for $750 thru a importer in Brisbane, just deciding whether to get it now or later for the conversion.
nope, no gearbox yet. i need to get it here so i can find out what type it is, as i've been told there's a push and pull type gtr gearbox for R33...
no rush anywho, i need this cast off before i can use it
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
