er... when i get some money saved for it. i have almost all parts, just need to find time.
Oh and i'm waiting to get my brothers R33 registered so i have a car to drive around while it's in the shop.
i'm guessing within the next month or 2
  • Replies 297
Good work, Darrin.
Looks the same as the one in my car, which is apparently (according to Beastien) the series 2 console. It looks like it has the glvebox that opens both ways - either towards the driver or the passenger.
wow I just read that whole thing
there went my day ,
I do have a idea with the surround for the shifter, friend of mine had a guy do some custom plastics work for him in his liberty for his foldout head unit ect. was 100% mint work * ill dig the photos up later *
anyway . I’m thinking personally ill ditch the cup piece at the back . and have him put in the slot for the hand break and edit where the auto went to put the piece under there for the gear boot.
stuffed if I’m paying 2k for it all :)
I havent pulled mine apart yet. but how is it under the auto peice. ie, is there enouf room to mount the handbreak gear. is there much junk under there the auto shifter sits ?
`josh
Yeah there is not too much stuff under mine, and there is more than enough room for the handbrake, just make sure they weld yours in properly..... mine was held on with 2 or 3 tack welds that were done by an eplieptic monkey, so one day they broke, I havent got it fixed yet, not much use for a handbrake here in Rocky :)
Yep . got rid of my lovely s13 :)
only so far that much power on rwd gets you eh . wanted something bigger / and more potentional . let alone something newer * s13 was starting to get a bit old * plus still have a track s13 lol
So first move is to get rid of this shocking auto. Then swap the rb25 out for something with a bit more poke :D
`josh
Could someone please confirm if I have missed anything as I may be doing this swap over the coming weekend.
R33 GTS25 4WD Gearbox & Transfer Case (Push Type)
R33 GTS 25T Flywheel & Bolts
R33 GTS 25T Clutch & Pressure Plate
R33 GTR Quick-Shift Gear lever
R34 Clutch Pedal
R34 Brake Pedal
R33 Clutch Master Cylinder & Lines
Spigot Bush (for end of Crankshaft)
R33 Handbrake Lever Assembly
R34 Centre Console Assembly (to be fused with Stagea Console)
Do I need to pull my dash to drill the hole for the Clutch Master Cylinder?
So far I think I'm up to NZ$1500 in parts
Edited by tRUkbOY
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
