  • Replies 124
farking fark fark fark :):D :D ;):rant: :rant:
Got it, and it doesn't farking run properly......freezes every time it tries to load from the disc.....called sony today and they suggested vacuuming it to undust it (it is one of the first ps2s released). s till doesnt farking work and I didnt keep the receipt to either a) get a replacement disc, or B) exchange for a new ps2 / disc deal.
Anyone got a working ps2 they want to sell cheap?
the 'Ring' is to damn long. and the ia license test on it is a bitch.
Just won me a 'Sileighty' woo hoo.
i didn't transfer the 100K over either, spoils the game i reckon. just do the Nissan races and the Jap races they a worth a few hundred K
I have 27 cars. 18 of which i have won. what has everyone else got?
Has anyone finished the GTR streamline test, in driving missions?
anyone else played with B-spec? i like it except they don't always overtake when and how you want them to, but ohh well.
Nuremberg is awesome!! I love the narrowness and the long straights with hills.
I did think the $100k from GT3 did take part of the initial challenge of the start, but $100k really only got me a GTR and did that up to the nine's. It's not really enough to win anything more than the beginner tracks though.
Should have probably gone for something else. Notice how the GTR's braking is very crap? It should have some of the best braking with the Brembo's, but it doesn't :)
You'll need the PS2 Network adaptor for each machine ($70 from David Jones), a 5 ports switch and two CAT5 network cables.
If you get the Network adaptors, you can then also install an IDE hard drive into your machine.
Good Luck
Thanks mate!
So can you use a regular router? I've got a wireless router that's got 4 ports at the back. Is that good enough?
Yeah, the four port router should do it quite fine. Duncan, give Quantronics a call ( www.quantronics.com.au ). Sounds like your laser is on the way out. This is a very common cause and you shouldn't have troubles replacing it.
Oh, and Nurburgring IS INSANE. The first 3 laps i did in it (in stock R32 GTST + exhaust) I was going "This track is nuts!!! every 10 seconds"...
What did you use to plug your ps2 into the pc?
btw: the burger ring track is amazing!
I'm using the fusion HDTV DVB-t plus tv-tuner. its a high definitiion tv tuner for the pc but it also has a capture card built in. this would set u back bout $210.
a cheaper alternative, but just as effective would be to either just purchase a cature card or (i just saw this a few days ago on the net) a VGA adaptor for the PS2.
the basic advantages of the tv-tuner is that i can record video footage as well as watch tv on my pc.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
