Well I have finally found the problem to my recent thread on backfires and smoke.. my last cylinder is KAPUT...so now i enter the fork in the road as to rebuild and strengthen my current RB25DET or upgrade/crossgrade to a RB26DETT with either using the current single highflowed turbo I have or using original RB26 Turbos? If I went RB26 way then I would not going AWD but still leave it in RWD.
What thoughts or suggestions do any of you that have done this or known of someone whom has got?
Thanks
https://www.sau.com.au/forums/topic/65622-rb25-or-rb26-in-upgrade/
RB26 is a very expensive option (have one in my GTST) unless you can fit it all yourself - save your bucks & rebuild what you have.
Yes I know it can be exspensive, but what are the power output options like, I gather you will not gain a substainal difference from just rebuilding the engine? That the RB26 would give a better platform from which to grow into a beast :)
My goal would be to get approx 250-260rwkw from the car. Currently I am at 215rwkw and with the current turbo (just high flowed recently) and the new injectors, pump, stand alone ecu etc I think the RB25 will do the job if rebuilt properly. I think I would be able to get to 300rwkw with the RB25 as well by strengthing the internals with Aria pistons and some Tomei gear?
I do think with 250-260rwkw I will be very happy with as I am still looking at keeping it a streetable car.
do what i did and stroked the rb25 engine with a GTR crank :D Little bit of machining had to be done to block but didnt cost much at all. Also bigger head gasket and 1mm was taken out of the combustion chambers in the head to decompress it down abit :)
for less than 100cc extra, a GTR crank isnt worth the $$ IMO.
better spent elsewhere.
if you only want 250-260, jsut rebuild the 25.
Cost you 7k motor in and out.
RB26 might be a tad cheaper, but then its 2nd hand.
Your 25 will be fresh and if looked after will last for years.
Yeah well they are all good suggestions and if I have a good amount to spend, then I would most likely go all out. However me thinks sticking to rebuilding the RB25 with forged pistons, rods and bolts along with a new engine & head gasket and regrounding the crankshaft to harden it and add new cam gears and valve springs and poncams. This way I am pretty much assured the engine will handle 400+kw and take me into the low 12's with the rest of my setup.
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
