saw a modena, sti and a few other cars cruising round shepparton today with numbers n shcctickers on their cars
dutton on? or is it just a hob knob wine n cheese weekend?
Nah mate the Dutton is on the 29th to the 31st of July this year.
Alan
More likely the rally they have each year for the GP...too pi55ed/hungover to think of the events correct name
...which raises a question? How many people doing the Dutton this year?
Yeah the GP rally.
Sounds good roy, you need a co-driver?
Co driver...lol yep. Ive got an idea whick im chasing thru at the moment that may mean some good coin comes my way in sponsorship. But im betting iy will fall over:(
A few ppl have talked about it, but no one has committed. Doughboy/skyline_geoff/Emre, i think Doughboy is the only one not scared that the car will blow up:)
Are you and Fatz in for the NSW Dutton?
i might have a go at dutton, whats required exactly?
motor blowing up sheesh.... theres nothing more exciting than blowing one up :D get off the loud pedal and notice u only have 4 cyl :(
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
