Finally got around to getting my fmic installed (gtr r32 cooler on r33 sedan with usual mods, pod, exhaust, dump pipe)
Decided to go with a mob that did a custom plenum and throttle body with the fmic install (got a good price as i did some pc work for them) and liked teh sound of clearing some space above teh engine
got the car back and its running terribly (felt like a misfire bigtime hitting boost)
got it dynoed today and the tuner told me that basically the standard computer is having kittens all over the shop (injectors are maxing out, computer is throwing up fuel cut and going into limp mode when booting it in 3rd and 4th gear, sometimes second)
i was originally planning on going a power fc relatively soon after the install, but the tuner told me that it wont do teh job because of the mods to the plenum and throttle body and the associated sensors, is this the case?
hes told me i need to go a motec M400 (like 4grand worth)
do i have other options?
ive turned the boost right down and am basically just going to put around to not risk blowing up the engine;
yeah would like to see some pics of modded plenum.
What boost were you running when it was running ruff, but I wouldnt think a standard turbo would make the injectors max out anyway??? unless you were running huge boost but then you'd be picking the exhaust wheel out of your dump pipe.
I would be taking it to another turner anyway to get a second opinion anyway before you go buy a $1200 PFC or a $4000 motec
ok, got the car sorted (props to motsons in brissy)
somehow the first mob i went to, missed that the timing was way, way out (33 advance)
that the tps hadnt been reset/calibrated correctly and that the throttle cable was sticking
car back in tip top shape and awaiting engine managemnt
ill post some pix of the custom work as soon as i get the pix online for those that were interested
some pix of the custom plennum and throttle body for those that are interested
all i know is that the throttle body is off a ford (i think its a 5 litre ford throttle body . . .)
http://members.optusnet.com.au/davidbrough...hrottlebody.jpg
http://members.optusnet.com.au/davidbrough...erthehoodee.jpg
http://members.optusnet.com.au/davidbrough...hton/thecar.jpg
well, coz the dramas i had after the work (see above)
im just runnign around on 6psi atm (wife made me, she didnt want me breaking anything again);
that said it scoots along quite nicely
ill get my engine managment done soonish, so ill post a dyno then
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
