Hmmm, some great deals here Dan, I might buy a few of ya coz they are so cheap and stuff like that. Your the best, man. I priced up a few from a couple of other cheap mobs around and your prices are low as an alter boy on sunday morning. I'll take one of everything yeah!
  • Replies 288
Some education for members at this newly upgraded site...very informative for anyone who doesn't know how a turbocharger works, read through from beginner to expert.
http://www.turbobygarrett.com/turbobygarre...bo_tech101.html
also what the best price you can do on a 450hp gt30 with a .63 exhaust housin (t3 flange) 4 bolt exhaust port... and a .70 ar compressor housing, externally gated of course.
cheers.
I ma also interested in this setup - but someing in more of a 500 - 550hp range, and internally gated.
Price for GT30R is on the first page of this thread
This has a T3 flange, external gate and 0.7 a/r comp housing plus is rated at 400-500 hp.
Closer to 400hp in the 0.63 but around 500hp for the 0.82 a/r
This unit is twin ball bearing. SKYER said GT30 which is journal bearing...there is a difference. R means ball bearing
IS your mate able to put oils seals in a pair of toyota ct12a's i pulled off my car?
Any idea on cost to do so?
I am 90% sure the oil seals are gone but is it possible to work out if they are without pulling the turbos apart?
Only thinking about doing this as opposed to buying another pair as these are apparently high flowed and steel wheeled.
Thanks buddy
Jamie
  • 3 months later...
I am also doing Highflows for all RB20DET and RB25DET Turbos.
These turbos are rated between 350-400hp. And include replacement shaft, comp wheel, turbine wheel, bearings, seals, machining and all labour.
Total cost of $1900 including remove and refit if you live in or around the Brisbane area.
This includes after tune with the consult to set boost level or fuel pressure if required. All work is guaranteed.
  • 1 month later...
Looking for info and cost of a T3/T4 hybrid to suit Skyline R33. Don't know much, but I know what I want.
Best to speak to Slide. He can do them a lot cheaper than me for that particular combo. Getting some good results too from what I hear.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
