Hey guys,
Got my air con regassed 2 weeks ago after it was drained in Japan. Had it leak tested, etc and it was fine. Now the air con is warm and there's no gas in it. Took it back to the guy who now says the metal line from the firewall to the compressor is stuffed and leaking gas?
Wouldn't this have shown up on the leak test? How does a metal line leak anyway? Is he talking shit and if not does anyone have this line in non leaking order :)
cheers!
https://www.sau.com.au/forums/topic/66258-r32-ac-help/
normally hard to pick up leaks unless gas and dye has been put in system and then leaked out again, the uv dye showing the leak.
tho the leak should have been picked up if he says he tested it, normally the system is pressurized with nitrogen or lpg etc, and the leak can be heard.
it is very common for the aluminium lines to leak, they are quite thin and can crack and bend easy, especially if they rub against something
usually if u cannot find a replacement line, the leak (usually a small pinhole) is welded up, this will fix it.
https://www.sau.com.au/forums/topic/66258-r32-ac-help/#findComment-1235271
cheers dude, yeah it was pressure tested and dye tested... he said it seems its leaking around the valve closest to the firewall.
i'll let you in another thing and that is r32 would have originally been charged with r 12 refrigerant. The ga we use now is a smaller molecular structure than the old r 12 . So this means even if you get the leak fixed it will eventually still leak thru the rubber hoses. answer replace all hoses or keep spending good $ after bad ?
https://www.sau.com.au/forums/topic/66258-r32-ac-help/#findComment-1237202
It was recharged with R12. That's what the sticker he put on it says. I'll get it redone if its just seals,
When I did have it I noticed the smell of gas every now and then and condensation appearing on the top of the console near the vents. If that's the case, how would gas get into the vents themselves?
this blows! I was looking forward to air con again :)
https://www.sau.com.au/forums/topic/66258-r32-ac-help/#findComment-1237438
Well if he did that it is against the law it is good to replace with SP34E as link will explain,
http://www.solpower.com/sp34e/sp34emain.asp
If he put normal 134A in it dosent mix with the oil in the compressor from R12 or along those lines.
https://www.sau.com.au/forums/topic/66258-r32-ac-help/#findComment-1237789
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
