Well I just went and cleaned it and gave myself a bit of a surprise; it is actually a Trust cooler not the stocker. Obviously replaced in Japan before the car got here. Trust is stamped on the top and bottom.
However since this is much much bigger(and also worth alot more) than the stock 34 cooler I am going to make the price $250 ono and buyer pays postage.
Pictures linked, you can barely make out the Trust stamping due to the flash on the camera but if you look closely it is there.
http://home.iprimus.com.au/nrodwell/IMGP0171_2.JPG
http://home.iprimus.com.au/nrodwell/IMGP0172_2.JPG
I'm interested, but do you have a better pic it, one with the logo? That picture doesn't really do it justice if it is a Trust cooler. Also, what are the measurements..
Cheers.
I am very interested!
Measurements would be good so I know just how much bigger/thicker than my stock GTT one. Happy to pay freight. Not sure if it will bolt straight onto 33 but if it came off your 34 then it will fit mine 100% :)
Thanks
Ok heres some better pictures showing the stamping on the top and bottom. Ignore the dirty garage carpet. :)
Size of the core is 240mm long x 190mm high x 100mm thick.
http://home.iprimus.com.au/nrodwell/trust1.jpg
http://home.iprimus.com.au/nrodwell/trust2.jpg
Unfortunately thats a bit of a "How long is a piece of string?" question.
As it is a much thicker core you should expect some power gain, and less heat soak, however the exact % will vary for each car.
The intercooler is not the limiting factor in how much boost you can run, its the turbo and all the support systems. For reference though, I was running 13psi on it with no issues.
Gtrghostdog,
Yes the cooler would be more than adequate for that setup. You will need the short 90 degree pipe and a silicon reducer and two clamps as well. These are included in the price.
http://home.iprimus.com.au/nrodwell/hoses.jpg
But Razorsharp is in the process of putting a deposit down so if that falls through I'll let you know.
the IC should come with a small bracket that bolts to the rail, the 90 elbow, the rubber/silicon hose (AFAIK it is not a reducer and is rubber) and the various bolts and nuts. the IC bolts straight up to an R33 with a bit of fussing around. ducting the bugger takes a bit time but worth the extra effort.
Hey pushhead, did you have to modify anything or was it a direct fit?
Also, how much is postage to SA?
Can you find out asap, as I am quite keen.
for an R33 GTS-T with M-Spec front bar, I did not have to modify anything at all. Remove stock intercooler and replace it directly with this. I haven't dyno my car to compare it with the stockies but I can tell you it felt like the turbo spool faster. I'm very surprised that no one actually jump in and buy this quickly. For $250 this is too cheap seriously. dont want to spoil anything but errr these cost just abit less than a trust front mount assuming trust front mount are $1500 new these go for $1100 roughly new.
I was next in line if the deal with Razorsharp falls through!
I am very keen to buy this and have the money ready and waiting!!!
Gtrghostdog would be after me technically.
Gtrghostdog,
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
