At first I thougth it was just a changed center cover, but Then (as you can see in one of the pics) it has N1 turbos, and to honest, I don't see any marks on the bolts as if it came factory that way. Anyways Iám buying the engine becouse is in good condition and has everything (engine, tranny, wiring, ecu, etc.) and I can get it for a killer price
how do you know its not just a standard rb26 with a changed cover and turbos?
34's have the red covers. if anything Id say its from a 32 looking at the ware on it but who knows with serial numbers
That's one option. but I checked the bolts on the turbos and everything seems untouched, I mite be wrong, but it looks factory. The engine is in pretty good shape, it's very dirty because is been in this container for over two years.
My guess....
If I remember rightly Nismo made (modified) about 100 X R32GTR's, and sold them (new) though selected dealers. They had N1 turbos, water and oil pumps and the larger dumps. They also had a body kit, different wheels, spoilers, Nismo intruments etc etc. They sold for almost double what a standard R32GTR sold for. The engine number will provide the answer.
:cheers:
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
