had a set on my r32 gtst, all rims are the same but rubber is wider at the back from factory. front tyres are 225, rears are 245 bridgestone potenza's good rubber, easily fit on the front but barely fit on the rear of 32gtst need guards rolled/lipped and hard suspension to fit the 245's. look great though.
in know way do i know the seller of these wheels, just giving buyers some perspective if you want to see what they look like on my old car pm me your email and i'll forward you a shot they look the part.
Greg
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
