Originally posted by GOT BOOST
cheers for the pics
ive been playin with turbos and i tried a larger front cover and wheel on a standard rear sized turbo. down low pulled ok but the top end lacked punch. the small exhaust is like a cork up its arsend.thats my thought anyway.
What was your 60ft / 330ft and 660ft times / also the mph of the 660ft and terminal mph and time. This can tell you where things are coming un stuck.
why turn neons on while at the drags looks silly and potentially dangerous also robs u of power
All after me
Your so rice it's unbelievable, Your so rice it's unbelievable.....
And whats with Soarers, I thought just West Perth was packed full of them it appears their everywhere:eek:
Wow! It seems there is quite some passion about the "Lit-up" Soarer! Well I have to admit to you that - that particular Soarer belongs to me. I respect that everyones tastes are different so some (eg: Skyzerr33, jmp, gradenko and puckish) may think it's rice, butt ugly and/or the person driving it is a tool - and that's all cool - you're entitled to your opinion! I'm not offended...! The car managed to pick up the "Mr TRD" Trophey at the 2002 PAS Western Salon and a 14.2 on the drag night so it can't be all that bad - can it !?
The car is a bit of a project for a number of Perth based initiatives. For one I am also the President of the Soarer Club for Western Australia so that was in part why there was a stack of Soarers down there on Wednesday. And hey, don't knock the Soarers! both the V8's and Twin Turbo's did pretty well on the night! I certainly can appreciate the skylines and if I had a second choice a Skyline would be it.
Secondly the car is a promotional vehicle for my business www.importscene.com.au. Specialising in auto accessories for the import market. And yes I've seen previous threads regarding the "rice" component. But again I'm fine with that. You either love it or you hate that stuff, personally I love it and a lot of my customers happen to be standard Aussi blokes many of whom own skylines!!
So at the end of the day this car is a bit of a promo vehicle for me and it needs to be seen. I also happen to love the neon look (each to their own) and if that makes me a tool in the eyes of some of you well so be it ! I'll still be down at the drags (trying) to kick some whoop ass....! Next time you see me at the plex come over and have a yack I'll be only to happy to listen to you dis me off in person! I think you'll find I don't take too many things that seriously :(
By the way "EXIT" drop by the shop sometime in wangara and I'll give you a generous discount for having such good taste!...
Cheers guys - enjoy the scene... :D
Gregg
The only soarer I didn't like was the white one with the *huge* wing, long sticker and plate style rims.
It's just not my taste.
However, that blue/green one with neons didn't look bad but I just don't believe that neons belong on the track.
Also - Good luck with the shop lextc, nice to see a import style shop in Perth.
If neons and rice is the best way for you to express the love for your car, then I'm glad you stuck with your first choice.
personally I love it [rice] and a lot of my customers happen to be standard Aussi blokes many of whom own skylines!!
And thats the shame of it all.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
