I'm after a pair to fit onto an R33 GTR. I'm not really fussed if they are new or used, but need a pair ASAP.
Feel free to call 0407 931 097.
Hi,
I've a brand new R34 N1 Turbo (pair)
interested pls email me at [email protected]
cheers
there is different r34 n1 turbos around , i found out when i was in japan recently so i bought gtss's for mine .
I have r33 n1's in my r33 now and they are great , 2530's are old turbos now .
I didn't think the N1's were as good as HKS turbos, just a general idea i've picked up...
can anyone list differences between N1's and HKS 2530/GT-SS, ie what kind of bearing, what are the wheels made from etc?
what do u mean by different R34 n1 turbos? Any part numbers to distinguish??
Yea thats it about 4 or 5 different part numbers and some of them you have to buy the bigger housings seperate so you buy the so called n1 turbo and it comes with the smaller housing then you buy the bigger housing .
The ones i saw on actual cars( Nur spec ) all had the bigger housings , same as the ones i have on my 33 now .
Ferni , all n1 turbos have steel wheels , only r34's have ball bearings , 33 have 360 degree bearing and 32 have 270 .
They are rated about the same hp as 2530's .
  • 1 month later...
ok what numbers are we needing to know to make sure we get the R34 GTR N1 larger housing as part of the deal!
here I was thinking getting either the 2530 or N1 34 was the way to go! but now there are at least 4 types of N1..... hmmmm
help!
oh and if any kind soul has a set of either of these please PM me :)
the bigger .64 sounds nice!
hi ok, all of the r34 n1 turbo's i've seen have had the same housing specs. .64 rear with .60 front. the only ones that didn't come with these specs are the r33 n1's which have small front housing and sometimes small rears as well. all the aa401 aa402 and aa403 have had these larger housings. between the 3 types of r34 n1's the only difference has been in the trim of the front compressor wheels. the later is the pick of the bunch. all of the n1 turbo range mostly use inconol front compressor wheels but all have steel rear wheels.and yes only the r34 series is ball bearing. ok on the topic of hks gt-ss turbo's compaired to n1's ok where to start. basiclly a hks gt-ss uses s15 compressor wheel with hks gt2530 rear turine wheel(or gt2871rs turbine wheel for u aussie turbo nuts as there exactly same wheel) the gt-ss hks turbo's on gtr use very simialar(near identical) housings to the nismo r34 turbz. .64 rear whit .60 front. basiclly the gt-ss will run abit more hp thanks to it's slightly larger rear turbine wheel thanks to it flowing more exhuast gases meaning lower back pressure meaning more hp. also meaning it can run alittle more boost as well and still being ifficient at the same time. any ways just some info
Mark
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
