Whilst walking around town I've noticed quite a few VL Turbo's in Adelaide.
I used to have an r33 gtst and naturally I'd imagine handling, interior etc to be far superior.. though how does a 'typical' street driven VL turbo cut its mustard with the rest?
https://www.sau.com.au/forums/topic/67006-vl-turbos-so-how-do-they-stack-up/
Well being RB powered they can absolutely hammer with only a little modification
stock they're comparable in acceleration with a stock R32 I'd imagine, a little quicker than a stock import R31
but yeah there's not many stock ones left these days, most of them have a decent exhaust and intercooler stuck on them, more boost, computer, injectors yadda yadda
a lot of them on the road are 13-14 second quarter cars or better these days from my experience
handling and braking..... live axle rear hurts, Australian R31s are closest in design and handle better
Braking they have 4 wheel discs as opposed to n/a VLs which are disc front and drum rear
I think the turbo ones have bigger front rotors and corvette calipers
Similar size to R31 and R32 front brake setup i'd imagine
befor my vs cluby,r32 gtr i had 3 vl bt1's yeah they do go very well as all rb enignes without spendng too much,
they dont handle and the interior is plain and the worst thing is they are still going for way too much as they are the most popular car to get on your p's.
it all depends on what you want and how much attention you want from the pi$$gs..
i had one before my 32 and all i can say is they are awesome in a straight line but thats about it, i loved my VLT and had it for almost 2 years but i definitely don't regret selling it to buy my skyline they are just so much better engineered
I was impressed with my first ride in a vl turbo. Had a 5 speed, no intercooler, bov, boost set at 10psi. Love the torque of the 3litre. I picked up an r31 with an auto a couple of months ago as a run around, must say for a car with 340,000km its surprisingly bloody reliable. So far ive only got good things to say about the old one cam 3 litre.
Low 13's is very good for a 304 that rolls off the factory floor running a mid to high 15. :rofl:
No doubt it would have a really nice sounding cam.
A mate of mine ran a 15.8 in his stock auto 304 VL down the 1/4.
Thats pretty crap when my old R31 can do 15.9
Up the corty! I used to own a TE 2L. That thing went hard for a 4cyl. I could keep up with VN's etc in first gear (then they would fly past). I could flog 202 commodores and 253 kingswoods though. I even beat a few auto 200 6cyl cortinas. It actually kept up with my R31 in first. It was a bit of a hole shot hero (compring shitboxes that it) It could do awesome burnouts too. Perfect first car I reckon.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
