  • Replies 116
Good news, they should be here within 2 weeks, so I'll PM off DD details sometime this week.
It's $110 + post now :)
Yeh, Great news :)
B.T.W. I just saw almost the exact same wheel nuts on NENGUN for something like $230 per set delivered to Aus. I like $110 much better :uh-huh:
ed,
Just a thought. You might want make the maximum torque value "bold" on the original post so you are less likely to get people stripping the nuts and complaining. I know many people who believe that wheel nuts are not tight unless you stand on the end of your breaker bar and socket. No Joke !!
And just for info sake, 120Nm = 88.5 lbf-ft ( foot pound ) for non-metric idiots like me.
Guys,
So sorry, I am being stuffed around by the supplier.
He is now telling me this week or next week.
I give up.
:P we all have days like that.
the question is, do you think they will make it or not?
If this falls through ed, let us know straight away. Dont keep us hanging.
If all fails we can arrange a group price from greenline. They do Rays nuts for like $150, so with 10 ppl we could get it down I imagine. I also have another possible supplier of rays nuts. same colours.
Guys,
Sorry for the slack responses from me.
Have been haggling and busting the suppliers nuts.
They have been sent via EMS so I should get them sometime this week unless he is lying about sending them out :P
DD details will be PM'd tonight.
If this is how the maker/supplier treats his customers...how do any of us know that the product we will be getting isthe quality they claim.
Im out. I want my wheels staying ON the car.
For the extra 80bucks or so to get Rays wheel nuts. At least I'll know they are tried and proven.
Phil M
ed please comment.
If we're not getting them...  I'll organise a Rays wheels nuts group buy.  Will be a maximun lead time of two weeks.
I think we "might" be best to see what ed has found out as I just had a look at the Rays wheel Nuts on Greenline and for the longer nuts ( the ones I'm after ) I calculated the cost to be 210.72 ( 17,140 Yen ) PLUS shipping etc.
I know that the Rays ones are different since they are 7 sided nuts and not 6 sided like normal / the ones we will be getting.
But after saying all that, if this group buy doesn't work out, I'm very interested in a group deal on the Rays nuts if the price is right :)
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
