One has to wonder if the turbo you are running is better suited to the rb20 than the HKS2530.
It would be very interesting to see back to back dyno runs.
Well this is a little off topic.. so... this turbo on the rb30 with the larger exhaust a/r might be quite a good responsive thing. :D
  • Replies 101
Ok, so i know the rb25 (r32) head uses same injectors as R32 gtst, someeon mentioned changing over to GTR items later on, the R32 gtst are high impedence and the gtr low impedence, does this make a difference/complication......will aftermarket computers handle this?? Whats the go with injector impedence. Coz the above mentioned injectors are both top feed...that much i know.......
Cheers
Geordie
mr_rbman,
For engine mounts head down the Shaun at Boostworx.
I bought my R32 RB25 head 2yrs ago from Adelaide jap for $750.
Take what Adelaide Jap say with a pinch of salt as they really don't know what parts are from what car.
They claimed my RB25 head was a R33 RB25 as the R32's didn't have a RB25 lol.
This was 2yrs ago so they may be a little more informed these days. :rofl:
engine mounts i will do myself as i am a boilermaker and things like that r a piece of piss, i hope to do most things myself minus the wiring up (no idea with electrical things) and the tuning which i will be seeing Shaun at Boostworx for!
Never deal with Adelaide Jap, have had the same experiences as u with them and will never go to them again!
Its a lot of money to get so little power, i mean POWAH. But if i could be farked i have priced an RB30DET for about $6,500, thats with cams, pistons and rods. $7,000 with a bit of porting
Then i would need to get my TD06 rebuilt and hi-flowed using either a 25G compressor or a GT30 wheel (and back to 10cm exhaust housing) About $1400..RB25 gearbox and twin plate clutch with modded tailshaft. $3100
So to go from 235rwkws to 335-350rwkws it will cost another $11,000
This is not an unusual question faced by R32GTST owners, thinking about RB30/25 in their car. So it is releveant to this thread.
Have you worked out how much you could sell the RB20DET for, complete with turbo, clutch, gearbox etc? Basically everything that you don't need. Keep the PFC, intercooler, exhaust, AVCR etc. Basically everything that complements the RB31.
Secondly, 350 rwkw's is a bit low for a $7K RB31, more like 400 rwkw. And at Philip Island you can use it, you were there and saw the blue car utilise that amount of power to win a National Championship.
It is horses for courses:cheers:
Tunned my car a bit more yesterday, my RB30det made 290 RWKW on 19.5psi, still using the stock RB25 n/a cams, and stock VL bottom end. Cant wait to get some decent cams in it.
That's getting up there in both power and boost. What's the A/F ratios look like?
:cheers:
Joel-cams im getting are tomei 260 degrees 8.8mm lift for both inlet and exhaust, which makes a fair improvement over the stock items.
SK- I set the A/F ratios to run at flat 12:1 at full load, using bosch o44 and rx7 injectors. Its a fair bit of power for a stock motor to handle, be interesting to see how long it lasts. Ive kept the rev limit fairly low at 7000rpm.
Sounds OK, just don't be tempted into running a "just bit more boost" or "if I lean it out a little bit I can get to 300 rwkw". Resist the temptation.
You will find the cams make a heap of difference. I will be interested to see how much the boost drops with the increased efficiency.
:thumbsup:
SK- If i was to run more boost with the correct a/f ratios and ignition timiing , do you think the motor would handle it??
Joel- On the dyno it makes peak power at around 6000rpm, and starts to drop off, but on the road its hard to notice this, and it seems to pull hard all the way to 7000rpm. not too sure why.
Darren- The tomei cams are RB20det cams, they also fit the rb25de.
valve float/bounce = pump up. :thumbsup:
Sounds good Sky30, peak at 6000rpm is a nice rpm point. :rofl:
I'm sure you have seen this dyno graph of a GT30r.
The 3ltr definitely looks like it needs that better flowing exhaust housing to get its higher rpm VE up there to prevent power flattening out.
    • I like their veal scallopini.
    • Definitely a hearty eater when we go out, I consider these meals my cheat day as I've been watching my calories in and calories out pretty hard since my little fun size stroke, I've gone from a fat boy of 89 Kg, I'm only 165cm tall/short, down to a almost semi lean 73 Kg over the last few years, I'm currently around 17% body fat which my doctor is very happy with, but, my goal is to slowly get down to and maintain 15%,so yeah, I want all of the protein, carbs, fats and sugars when I go out for a binge
    • There was a great one on Victoria Rd in Gladesville too back in the day. I can only assume GTSBoy is thinking of the mill up on the wollondilly, no restaurant there any more but they have restored the original steam engine on site and run it every few months, have an annual steampunk festival etc @The Bogan, you came to the wrong town for restaurants. we have a few reasonable asian and indian options but the Paragon is as good as it gets otherwise. That brewery is apparently just opened, been meaning to give it a go some time. The Highlands have plenty of fancy options but I suspect you are more a hearty eater than fancy eater
    • Thanks for coming back to post the update, maybe it will help out the next person!
    • Going by the intake & injectors I'd be guessing it's a DE, check the head casting number, should be 5L8 on a DET, 5L7 I think is the DE number.
