Rb26 is still nearly 1/2 a litre less than Rb30, torque is still gona be a fair bit less.. All 3 boxes i destroyed had stripped 3rd gear, every time it happened i was accellerating hard in 3rd, then BANG.... One decent R33 box is cheaper than several Rb20 boxes.
  • Replies 101
just curious how would this conversion go in a A31 Cefiro? and gearbox wise i've heard that the best gearbox to use for a cefiro drivetrain conversion is a VLTurbo MX7 gearbox because it runs a cable speedo drive? and out of the MX7 and the R33 which is the better box would they handle alot of power and which one 'feels' the best for those with experience? cheers
do a search for how much they are. (~$1500) You just need one in good nick and it will last. No it wasnt difficult to put in, because i bought the setup out of another r32 (came with tailshaft modded, gearbox mount, and speedo drive modded)
Yes, i was running the rb20det b4.
heard of that. ;) They say because you are driving the car on SA roads, YOU are still responsible for it. They still defect it no matter what....
Nope, Commonwealth/State Law doesn't work that way, if the car is legal in Vic they can't defect it in SA. Take the defect sticker off and post it to them, with a thank you note of course.:D
The R33 gearbox feels alot smoother than the MX7. Most MX7 boxes have got high kms on them, there usually noisy and notchy to shift gears.
I used the stock r32 tailshaft and got a VL turbo yoke (or R33 turbo) welded on the front, overall length was the same.
SAPOL do what they want Gary...they can defect a car with interstate rego, and have done before.
Sending them the defect sticker will result in a nice fine as well....
I don't care who they are, they can't issue a defect notice on a car that is legal in the state it is registered in. This was tested many years ago in the Federal Court, Queensland had different registration laws with regard to extra lights. NSW tried to defect the trucks carrying the extra lights (that were legal in Queensland), they lost.
This case (and few others) is the reason why all the States signed the national agreement on common ADR enforcement as provided by DOTARS. SA has broken that agreement, if anyone takes SA to the Federal Court they will win.
A copy of the agreement is availabe under Freedom of Information from DOTARS.
:D
Im on your side Gary...when I get my car finished i'll be taking it interstate to more than one place to have all the ADR tests etc done to make sure its legal....
Ive had a cop on a bike pull up next to me and say "if i hadn't just worked a 13 hour shift, i'd defect you for your blow off valve". Then the lights went green, and he took off (from a right hand turning lane) and pulled infront of me to continue stright down the road.
Now without seeing my enginebay, how did he know i had a blowoff valve? And yes I do still have the STANDARD blowoff valve installed in the car.....WTF!!!
Its a revenue raiser for SA, and things are not going to change here (cops issuing defects) until this state gets WOF checks like other states. Until then they do what they like.....have a read of the regency thread in the SA section to see the BS they have gotten away with...(defecting ADR approved steering wheels etc)
I havent had any trouble with them as of yet (touch wood) but believe me i will be taking it as far as i can if and when the time comes....
/end rant....back on topic :D
Picked up my bottom end today, pretty good score i believe! Its a 1988 R31 bottom end with only 168,000kms! Looks to be in great nick, will start taking it apart soon and giving everything a good clean and inspection. Manged to score it for $150
Finally the journey of the RB30/25 begins! (8/4/05)
I guess we'll see how long it takes but i know that i can't wait to turn over the key!
Now you just need an engine stand. :D
I'm heading up my oldies tomorrow, I will grab it.
cool, my mate got his off Ebay but i reckon the one u got is better. Have you thought about a price yet? if so let me know and we can discuss me picking it up or whatever. Will it fit in the back of my 32?
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
