Hi to all,
I'm need here, stumbled here when i was searching the net for reviews of the R32 GTS... couldn't find any though. :rofl:
I'm driving a AE92 Seca Corolla at the moment, and i'm thinking of upgrading to a 4 door 32 GTS. Mainly because i'm still a young driver, and reasoning with basic logic, turbo = more air in = more power if more fuel in as well = not a very good fuel econ figure.
I really want a review on the 32 4 door GTS... i really like the look of the 32, and the 4 door because of its practicality... but what are the real world economy figures for the RB20DE hauling a heavy (compared to corolla :cheers:) body? Is it underpowered? Anything R32 GTS owners wanna share?
Thanks heaps for all your replies.
Cheers,
Jon
https://www.sau.com.au/forums/topic/67627-rb20de-r32-4-door/
http://www.autospeed.com/cms/A_2278/article.html
You need to pay to get a membership. I bought access to all the back issues (304 issues) for $80. I reckon it was worth it, but it depends how much time you would spend reading an online magazine. I think you can buy just the one issue for like $4 if thats the only article you want to read...
So long as it's the DE not the E then i think you'll enjoy it.
However, 4 doors are already harder to find than coupes, and most R32's are turbos so you're narrowing your options yet again.
Also have you contacted any insurance companies and found out what the price difference between cover for NA and Turbo? In my experience there's not a whole lot, the fact it's a Grey import works against the most, Turbo usually only adds a few hundred to Comprehensive cover and almost nothing to 3rd Party Fire/Theft with little higher excess too.
i'm not really concerned about the insurance point of view, because as u said, its a grey import, therefore the cost is already there; turbo or not it doens't really matter.
I'm concerned about the fuel ecnonomy aspect though, with the turbo... not sure how it would affect fuel economy. And also the weight of the R32 4 door might be an issue too.
if you are buying one, you better do it quick before the 15 year free for all ends, as a 4 door N/A will not qualify as a SEVS vehicle because it dosen't meet power to weight ratio requirements.
As for a GTS, my daily driver is one, great economy, better performance than almost all the other alternatives that are in the same category. RWD, handles well, reliable, can't complain... insurance is only $1200 p/a for full comprehensive as well over 12 monthly payments. Mine's a coupe though, but the 4 doors aren't that far behind.
If i was you i'd just be buying the GTS-T 4 door instead of the GTS 4 door, as they are pretty much the same in fuel economy, it all depends on how hard you drive it, and if you decide later on you want more power, which lets face it, we all do its much easier with the GTS-t
David
whats the widest tire width that could fit on the R32 GTS?
i think the GTS only has 4 studs ... so what would be the optimum size for performance?
as far as i know, for my corolla 1.6; 15" is the best on the track, due to its lower inertia and is wide enough to do the job.
also, is engine transplant a usual scene in the skyline world? In the corolla world, we normally get supercharge frontcuts and transplant the bugger over. Cost around 4K all up. i'm tihnking maybe if i outgrow the GTS... maybe plonk in a RB25DE?
I know first hand a RB26DETT bolts straight up to a RB20DET gearbox, the RB25DET would too, and i would assume it'd do the same with a DE. If you want to go for torqe you can always twin-cam a RB30 with turbos.
If you get the RB20DET out of the box you can push respectable power out of that too, but you're always going to be down on torque compared to other RBs. The other advantage of a DET is if you get a Type-M you've already got some awesome brakes with no need to upgrade unless you're doing a fair bit of track work.
The previous question of rims, I know 9.5" fit on the rears and 8.5" on the front, but you'd struggle to get any more on stock guards, esp. the front.
ic...
thanks for all the info guys.
so now i assume that if i actually get a GTS 4 door, i got a few things against me:
- insurance, since its a grey import, might as well get it turbo
- 4 stud wheels instead of 5
- brakes can still be upgraded
and the pros:
- cheaper
- economical even though u drive like a wanker
- if it gets slow, might as well mod it with the "works" ie 2.5L/ 3.0L RB stick some hairdryers, put some nice brakes... and its ready to roll...
....rb20det is pretty dam economical ...i get 11 to 12L per 100km city driving which i think is really good ....and 8 per 100km highway driving
u aint going to get much better than unless u get a smaller laser or corrolla.
my last car with a 2.4 L motor got min 14 in the city and min 10 on the freeway....it was an NA car
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
