Can people post up their best lap times. Any track. (Don’t forget the Nur :aroused: )
List:
Track (Reverse/Normal)
Car
Mods (Include TCS/ASM)
Tyres
Wheel or Keypad (With the wheel include wether your settings are on Amateur/Pro/Sim)
It’ll be interesting to compare our times. Don’t cheat it’ll only work if everyone is honest.
Thanks.
-Dan
https://www.sau.com.au/forums/topic/67647-gt4-lap-times/
We have this on another forum I use. As its a Ford Forum we have agreed to using Escort Cosworth, arcade mode, Nurburgring. We just post our times up from that.
There is a link on that site to a Japanese guy doing the ring in 4.54mins in an F1 car!!
My best in a skyline is about 8.00mins!
https://www.sau.com.au/forums/topic/67647-gt4-lap-times/#findComment-1255487
my PB at Nurburgring in a GTR R34 N1 with exhaust, chip and suspension setup does a 8:10 min so far.... but i agree with that if there is gonna be a time attack comp, we need to set a standard.
Since it is a skyline forum, i think we should probably stick to a stock GTR of some sort.
https://www.sau.com.au/forums/topic/67647-gt4-lap-times/#findComment-1255502
Yeah i think Archie is right.
Lets stick to Skylines on the Nur, how bout just stock factory models R32,33,34 Gtr's and Gts-t's and version wise the VSpec II the highest you can go. No driving assists no mods and sport tyres? (Basic factory specs)
I guess the times can only be comparable to specific models.
-Dan
https://www.sau.com.au/forums/topic/67647-gt4-lap-times/#findComment-1255664
I got a 8'01.104 on with Nurb with a Stock 400R, but that was when I wasnt used to it so I could do alot better now.
I got a 7'35.664 with a stock RUF CTR yellow bird (Hard car to drive on nurb).
and I got a 6'52.288 with a 535PS R33 GTR N1 (over 700 PS now so I could kill that time)
Tsukubas best time is 49.398 with the GTR N1.
NO Driving assists are used ever.
https://www.sau.com.au/forums/topic/67647-gt4-lap-times/#findComment-1256071
got 7'10 with r32 calsonic and racing soft tyres. hmm....how about we start comparing times and start off with a stocker 32 gtr in arcade mode with street soft tyres and move up to the next model next week. so every week theres a champ who gets "glory" and gets their mug superimposed on the face of schumacher or something?? LOL.
https://www.sau.com.au/forums/topic/67647-gt4-lap-times/#findComment-1257598
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
