When my car came over from Japan I got it dynoed @ 1 bar as soon as it came over and it made 274rwhp. Then we backed the timing off (to prevent pinging) and turned the boost up to just under 1.2 bar and it made 297rwhp. It did this with the Japanese chipped standard computer that the car came with. The AFR's were off the chart rich as soon as it came on boost and the overall tune was not very tidy at all.
I decided to purchase a AP Engineering Power FC to get the tune spot on and went to get it tuned. On the dyno the fuel and ignition were being played with but the car did not seem to be making decent power. Timing was around 14 and the AFR's around 11.8 with the boost set around 1.2bar. The motor was struggling as soon as it came on boost. At around 4.5k it stopped making power at around 240rwhp and then fluctuated between about 230-250rwhp all the way throught to redline.
It did not seem to be missing but we changed the plugs, changed the AFM with a brand new one and everything seemed to be working fine but the car was just not making power. To check it wasnt anything mechanical I plugged the Japanese remap in and the car once again made decent power so it has to be something to do with the Power FC.
Mods done to the car so far are.
GTR front mount
GTR injectors with resistor pack
Z32 AFM
GTR Fuel Pump
Decent sized Apexi BB Turbo
Auto to Manual Conversion
I have talked to many ppl about the problem and noone seems to be able to shed too much light onto what could be wrong with the tune. Can anyone offer any suggestions on what the problem could be? The only things I can think of is the Auto loom causing some kind of problem as the computer is only meant to be used with a Manual car only.
PLEASE PLEASE HELP. This is total :bs!: and is pissing me off and stressing me out
https://www.sau.com.au/forums/topic/67913-rb20det-ap-engineering-power-fc-tune/
As the guys have already suggested, ignition timing would be where I would start. Check it with a timing light at 5,000 rpm with the chipped ecu and compare that to the Power FC at the same RPM.
user posted image
Went and got some runs printed out from the dyno today. The blue shows the power fc tune while the green is half a run with the jap retune, it would have made around about 290rwhp+ with a full run.
The power fc is tuned with afr's about 11.8:1 while the jap tune is a LOT richer than that.
Will test the timing with the light toinght and get back those results tommorrow.
Once again thanks for the help
Looking at the power graph, my first guess would be that the ignition timing is all over the place. Since the boost and A/F ratios are stable, that's the only logical alternative. It's up and down more than 20 rwhp in some places. Very interested in seeing the A/F ratios graph and what happens when you run the timing light over it.:cheers:
']try some new knock sensors
i suspect yours have failed, and are retarding the timing coming onto boost
other options : test the power fc in another car to see if thats the cause.
Id doubt it would be them, as chaning ECUs shouldnt change those problems.
It pretty much has to be narrowed down to the ECUs tune and or wiring.
Id also just double check to see if their AFR metre gauge thingy it working correctly, as if that is out, then it would be throwing out their tuning something chronic. (had it kinda happen before, AFR line was fine, just down about 2 on what it should have been ie should have been at 12, but was reading about 10)
Why do you say to try comparing the timming at 5000rpm not say idle?
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
