Hi all, over the long buld of my engine and accesories i have come to a part where i am not that familiar with and would like some advice, the topic in question is turbo housings sizes.
I am getting a gt35r, power target of at least 300kw at wheels, what would be the top end and lag differences between a .82 rear housing and a 1.06 housing? I am told a .82 housing will be sufficient for that pwer target can anyone tell me of results or there oppinons about the housing choice and possible outcome?
https://www.sau.com.au/forums/topic/68012-turbo-housing-choice/
Peak power isn't everything. Its the area under the curve that is important.
I'm using the same turbo for my 3ltr.
On the 3ltr the GT35R .82 will only 'just' make 1bar by ~3600rpm, with the 2.6ltr, throw on another 500rpm spool time.
By 4500rpm it should be hauling arse.
Just as a comparison, the GT35R .63 flows the same amount of exhaust gas as the .82 GT30R. This is according to the turbine maps.
Squish on turbo motors is overrated !!.... :flamed:
When building a motor you build it to make the most power it can everywhere in the rpm range.
Especially on a turbo motor, you want all the bottom end torque you can get.
Why take a step backwards and open up the squish that Nissan have already setup so well. :flamed:
When you are off boost you want economy, put the foot down and you want the burn to be as complete as possible to get that big turbo up and spooling.
All of which quench come in to play.
If its 10hp well its 10hp.
If its another 40km's per tank well its another 40km's per tank. ;)
I think it would be very streetable. :(
I'm considering a .62/.63 what ever it is for the rb30det depending how the .82 feels on the road.
Generally the smaller the exhaust a/r the harder it hits, so you loose a little bit of throttle control.
I agree with that statement cubes - for this reason I would just go for the 1.06 and be done with it..
Just for interest, did you know that Honda developed 3 different turbine A/R's for Ayrton Senna and Alain Prost in the 87/88 season one small, one medium, and one large. The engineers assumed that the slow speed circuits would easier with the small A/R, and high speed circuits would be faster with the large..
After several tests, Senna found the car was more progressive and easier to drive in all situations with the large A/R, so they ran with it at every race and shelved the small and medium housings.
Cheers,
Matt
Should be interesting to see the real world results . Theory suggests that a .63ARR housing would mean that the GT35R is a little big , and as the turbine maps show mass flow drops with the ARR number . There comes a point where exhaust restriction overrules the advantage of high compressor flow capacity and a step down in turbo size with larger ARR housings may work better . It may be worth looking into lower ARR compressor covers to lower the boost threshold rather than the smallest available turbine housing . The Garrett engineers reckon the mid sized housings are where maximum efficiency is .
I don't deny that I'm a bit fanatical about turbine inlet (back) pressure as it has so much potential to limit power and damage things - pistons mainly . The GT35R is really a Garrett hybrid of 35 series compressor with 40 series turbine , if the strait GT40R was scaled down the compressor would be smaller than the GT35R's .
I've been trying to find out if the GT BB turbos can be rebuilt and or custom built , sort of like a GT35 turbine with a GT37 compressor . Its debatable if that compressor could feed an RB30DET at higher revs and boost but the turbine/housing would not choke it .
I hate to say it but Ford may struck the righ balance with the large turbine housing and smaller E type cover on the GT35R .
While I'm here I keep hearing whispers of new turbos and gated turbine housings from Garrett in the near future , anyone know what to expect ?
It'll be a while before I get to this stage , cheers A .
I always find your posts interesting discopotato. :D
Smaller exhaust a/r = less VE.
I see where are coming from where you say that a ford style setup (large exhaust a/r, smaller comp cover) may indeed give better results.
What turbine does the ford run? The GT35R turbine is huge, as big as a coke can.
The reason I ask that is if they run a GT40 turbine how do they get it all to fit?! ;)
Shane, gemini ron had a "even" turbo, as in front and rear were identical, and you know what that car was like. He's since had it flowed and got a new wheel etc put in it, so its effective size now is apparently a t60 or so. And it aint made anymore power from that (which it should have, more air being forced thru, and should be cooler). So Id look at having it balanced like he orginally had.
The turbo on the XR6 is the same CHRA as Garretts GT3540R , the turbine is 68mm dia and the compressor is 82mm . Its turbine is a GT35 series not GT40 .
I have to agree about the size of its turbine - massive . While the GT30R's turbine is 60mm and probably a tad small I don't know of an in between size , maybe theres one coming . It makes me wonder how the VLT got away with a 60 mm T3 turbine though they supposedly had boost from 1500rpm ? I was told the state of tune was very low ie 7.8 CR and only 4-5 pounds of boost with no intercooler . I'll look into GT40R's and let you know the turbine details .
Cheers A .
The GT40R uses a 77mm (3") 78 trim turbine in a .95 or 1.06 ARR turbine housing - huge got bigger . The compressor wheel is an 88mm (3 1/2") 52 trim in a .58 ARR compressor cover . From what I can find GT40 compressors can be 82 or 88mm .
Ever noticed how some of the later GT BB's are closer in wheel diameters ie GT28RS (54 and 60mm) , GT3071R (60 and 71mm) , GT40R (77 and 88mm) . A theoretical GT3537R or 3576R depending on whose terminology you prefer sort of follows the same trend (68 and 76mm) .
Also HKS spec turbos , when they knew the difference in compressor to turbine diameters was large they chose smaller trim compressors ie GT2540 - 46 trim , GT3040 - 50 trim . Extra airflow and an attempt not to overtax turbine shaft power .
Compressor choise absolutely affects a turbines efficiency which affects backpressure and volumetric efficiency .
High volumetric efficiency is probably difficult to achieve on a turbo engine given that the turbine , no matter how good , is at best a minor exhaust restriction . My understanding of high VE is where careful tuning of the inlet system gives a ram charge effect which overcharges the cylinder and gives very effective scavaging on the valve overlap period . Careful exhaust tuning can be use to create and area of low presure at the exhaust valve which also assists scavaging and cylinder charging . Turbos with a better ratio of compressor to turbine stand the best chance of allowing higher VE than the poorer spec ones . This broadly assumes the wheels are efficient to start with and the housings are appropriately sized .
Just for laughs I scaled down the dimensions of a GT40R to that of a GT35R's turbine diamater and the 40R's ratio puts the compressor diameter at 77.71mm . This is a crude way to look at it but its a tad bigger than the GT37 compressor wheel (76.2mm) by 1.5mm but smaller by 4.29mm than the GT3540R's 82mm GT40 compressor wheel .
Cheers A .
Actually the correct OD for the VL's T3 turbine is 58.9mm , same as FJ20 and Z18's .
Nissan got the CHRA's from Garrett and cast their own housings for them which is why the comp covers often have Nissan Motor cast into them . Don't confuse these with the later ceramic BB turbos whose cores were made by Hitachi and whos only resemblence to the T3 is the exhaust mounting flange .
Cheers A .
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
