  • Replies 77
Hi Judd,
Just wondering how much you'd ask for the power steering pump plus the power steering rack. Assuming its in good condition with no leaks etc.
Im getting a R32 GTS T , gas has been vented from the aircon so I would interested if it fixed my problem. Was after some stock R32 rims
sorry im not very mechanical, you might have to post in the technical section or something.
and i dont have stock r32 rims so cant help.
hey mate
im chasing a radiator, fan shroud, radiator pipes, ballast resistor and if you still have the passenger side air vent ill take it.
how much incl. shipping to brisbane?
thanks....brett
yep email me your price i will call around the wreckers and work out what i think its worth i promise to be cheaper.
[email protected]
yes i still have passenger side air vent
the lot must go..
big plans, no money.
RARE
late model 93.
Engine + turbz (77,000km)
gearbox + new clutch
interior (no rips no tears)
dash
thats the big stuff taking offers on the lot
5% of the sale of every item goes to SAU.
Do you have the drivers side seatbelt system???? could u please mail me at [email protected] or PM me pls
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
