apexi sell something *similar*, called an exhaust control valve - it doesnt bypass your exhaust, it can close it off/open it up...
useful if your car is over the db limit - hehe...
they're not too exxy either, only around $300 odd i think. it's manually controlled with a little cable though, not electric ;) but i was toying with the idea of modding it to be controlled with a push button and electric motor :D
EDIT: LINK!!! http://www.importscene.com.au/prod466.htm
i can only see those apex ones as hindering performance where as this one...pfft need we say more...lol my mate is considering purchasing one of these bypassing thingys if not a locally made ones. ill wait till he gets his first before i even think about gettin one:D
yes excellent....
until joe average runs his open all the time and sets fire to the underside of the car, or burns some lines like fuel / brake etc... at least plumb it out to side pipes or something
idiots.
PS did anyone read the "feedback" section?!?
haha does this constitute red neck rice?!?
yes excellent....
idiots.
lol..yeah side pipes would look cool on a skyline....mad max style:D
  • 1 month later...
  • 1 year later...
  • 3 weeks later...
My boss wants to fit a pair of these to his Hemi 300C SRT.
The thing sounds awesome as it is, but with a pair of these.... well, I think it would stir my pants somewhat.
JEFF.... BUY THESE!
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
