Bit harsh Andrew :D, i ran a 13.4 with my car and i am absolutely shit at drag racing. (Std turbo and engine, on my 19's)
I'm beting a 13.01, just to piss off Troy :), and to back up the initial bet we had btw us. I will try and be there and will probably help Shivam trailor his car there, if he still wants to.
  • Replies 50
:D heh i'll come down and show ya's all up with my 10 second car...getting the underbody neons installed this week, and i bolted the NOS in over easter :)
but in all seriousness i might come down and have a look/drive.
*cough* Drag is for commonwh0res *cough* :)
Is that all? lol
hehe no offense to you or you car at all... went to the drags with my mate in his GTST which runs 250rwkw, std injectors but has a power FC and a good tune... he ran around a 13.4@110mph i think... but had a lot of trouble with traction
i'm guessing if you have a good launch in you may be able to break into the 12s... but since its going to be your first time there and all, i'm guessing for a mid 13 :cheers:
Good luck!
Big thanks to Al, he carried my tools with him, bought me food, and put up with my dribble and excitement... RB20 POWAH!!!!!
I thought i would have been stoked to brake into the 12s, and a 12.9 just counts so im stoked. Best run ET wise a 12.9 @ 112mph with a 2.2 60ft time. My best mph was 114mph but i farked it up with a 2.4 60ft.
I had a ball...and once again big thanks to Al, it was goot to be able to share my excitement with someone:thumbsup:
lol..yeh, its a shamble at the moment...had a BBQ at a Winton track day, then kissed a tyre at a drift day...It was down hill from here:(
But things are looking on the up and up:) When my new carbon bonnet arrives its all going into the panel shop so should once again look pretty neat:)
As for the exhaust note...thanks, I love the sound of my thing, its the cars redeaming feature.:)
Should have come up and said hello, maybe next time:thumbsup:
LOL...2.2 60 ft with 234/40/17s semi slicks:( I aint the man. I need muffin man or you to get the car off the line for me:)
I fear im becoming a drag queen....i really enjoyed last night, more then i ever though ti would...it was way better then that grifting caper i did 2 weeks ago:thumbsup:
Will be back in 2 weeks with boost wound up to 18psi, I'll try building i bit of boost with the handbrake and see if i can get a 2.0sec 60ft time. I doubt ill be able to. But no im mega keen to try and get a 12.5 @115mph...just need way more practice off the line...:)
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
