  • Replies 41
Nah scissor doors are harmless...if you want to do it, do it. My own personal opinion is that the doors are fine the way they are, I'd be a bit embarrassed getting out of one that had scissors actually (unless it's a lambo :wassup: ) and frankly I just got a better way to spend a few thousand bucks.
https://www.sau.com.au/forums/topic/68386-scissor-doors/#findComment-1268637
Eug...i've been sussing kits out from the usa n germany, would be better to sourse onr from Oz thou.
Strutto....Hey mate! i got the top visual rateing a while back but couldn't get the wide body kit....how do u get that sucker????
Nismoboy...cheers mate, i'll check with Ares Speed after the weekend, haven't tryed ebay yet, ever, for anything, i would be a little wary of online shopping, not that puter smart yet to know all ins and outs.
Thanks for the laughs! each to his own thou i suppose, one kit that i saw had a switch/lever that changed the scissor swing to standard swing (LSD from Germany) i thought this would be the best way to go Silver'sR33 so then you wouldn't get to embarresed when crowds are around..hahaha. :cheers:
https://www.sau.com.au/forums/topic/68386-scissor-doors/#findComment-1268917
Mud,......thanks for the link, nice tunes, nice bit of skirt, but don't know if i like the way the door near opens 100% then goes vertical, i wonder if that design is pacific to VDC or all kits, it sort of defeats the purpose i think as you can get out without them haveing to go up...............MEL! Check out www.ultimatez.com for some power upgrades, they have a brilliant package deal there-cold air pod-headers-exhaust-pulleys n belts-clutch-flywheel...$3643.90us check the extra component kw....Mmmm will have to consider it i think.
https://www.sau.com.au/forums/topic/68386-scissor-doors/#findComment-1269890
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
