Hey Guys
I am selling these parts and require your standard parts in exchange.
I will pay for the conversion.
The prices are what was paid late 2003 and 2004.
Parts have travelled about 20,000 kms from new.
Apexi GT-Spec Drag Intercooler $3500
Nismo 600cc injectors $1500
Nismo internal fuel pump $600
Nismo fuel regulator $300
Bosch external fuel pump/swell pot/system $1400
Apexi dual N1 exhaust system $2200
HKS oil cooler $1600
HKS dump pipes $1000
Trust EO1 Boost controller $1100
Nismo turbos $5000
HKS 264 in/out cam shaft $1500
HKS drag pro valve springs $700
N1 oil pump $650
N1 water pump $250
Modified sump for oil surge $750
JE forged pistons/shot peened rods/head porting $12,000
HKS head gasket $1100
Motec M48 PRO ECU/harness/mapsensor $6500
OS Giken triple plate clutch $3000
Blitz BOV $750
HKS Cam gear $400
46K value.
I need 22K plus standard parts.
Car is here in brisbane.
Michael 0414561121
https://www.sau.com.au/forums/topic/68405-bargain-600hp-gtr-upgrade-package/
T88 ON BOARD: Read the post. The prices listed are only an indication of what he paid initially. Hes offering the package for sale for approximately half of what he paid.
I'm selling up my cars. I own a few GTRs and am off-loading them as need cash for property.
Wife and kids sick of the cars.
Different priorities now.
Cars must go!!
Guys, I've bought a set of wheels off this guy before, spoken to him on the phone and seems like a very reasonable and honest bloke...
So give him a break and unless your interested in what his selling, keep your irrelevant comments to yourself!!!!
Some of us are just wanting to keep an eye out for others around here. I also saw this guy try and sell parts off a car that wasn't even in the country (wasn't even a 15 year old eligible import).
rb31, please post pics of these parts.
Hey Guys
I've been around too long to get caught up in a fear/smear campaign. I don't have a credibility issue. I am the guy in the Serious Performance 6 DVD with the yellow Abflug if that helps any.
I am in negotiation to sell the parts now. I hope the moderator has the decency to clean up this thread.
Thanks
Michael
Happy to clean up the thread, I hope you now have the decency to answer my questions
The parts you posted forsale in the other thread were they in Australia and owned by yourself?
Are you a importer/trader?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
