last year got defected for my front tyres and couldnt afford to buy a decent set and settle for a set of nankang tyre,
6 months later....
with in a week, both have gone flat for no visible reason.
one of them went flat at work, while the car was stationary.
the other last night while driving.
unfortunately i didnt realise that night that it was flat, only when i noticed a slight noise and the car was veering to the right (normally goes to left because of bush)
pulled over and whaddaya know! FLAT!!!!!
now the tyre that went flat while stationary was filled up left for a while and had no leak??? after i got it checked out.
the second is now ruined because the steel belt was driven on while flat. i filled it up and again seems ok.
now what i did to test that tyre is put water between the tyre and rim and check for bubbles, NOTHING!! on both sides.
so basically im thinking the tyres maybe faulty and just not sealing.
luckily i still have the reciept and going back on tuesday to talk to the guy that sold them to me and see what he has to say.
anyone else have similar experience???
https://www.sau.com.au/forums/topic/68493-nankang-tyres-possible-fault/
have always found nankang tyres to be fine
maybe u had someone play a prank on u at work
the other one i have no idea.....
thats what i was thinking but after the second flat, i thought it to be weird.
and with the car 100mm low and a flat tyre also, it wasnt a funny practical joke
the most common reason for a flat like that is the valve not being inserted correctly, causing a slow leak.
But back to the tyre place sounds like a good idea to me
took them back
there seemed to be no fault at all
if it was a valve what are the odds of 2 in a week?
anyway the guy sdaid understress it would normally be vlaves but he said its hard to get good metal ones
most are shit and leak
hmm I couldn't afford the tyres I wanted either so I got 2 nankangs on the back for blue slip (making it 4 nankangs on the car... 4 too many) - haven't noticed anything with em yet.
will keep an eye on them - good luck to ya let us know how it goes.
I had a set on my line for a while, and they seemed like any other low quality tyre, kinda sandshooish but legal.
Flogged them without mercy, never had any dramas other than a lack of smoke, grip and cred :)
Other then this problem how would you rate these tyres? for around 700 you can get 255/40/17's on back and 235/45/17 on front pretty cheap. Whats the grip like? do you think you could get anything else better then nankangs same size for around $700?
Cheers,
Paradizzle
How often are you guys checking your tyre pressures? Every car I have ever owned had sloooooowly decreasing tyre pressures, some worse than others. Brnad of tyres makes no difference they all leak something. I check mine once a week after I get them, then once a month if they haven't gone down noticeably after a few weeks.:cheers:
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
