last year got defected for my front tyres and couldnt afford to buy a decent set and settle for a set of nankang tyre,
6 months later....
with in a week, both have gone flat for no visible reason.
one of them went flat at work, while the car was stationary.
the other last night while driving.
unfortunately i didnt realise that night that it was flat, only when i noticed a slight noise and the car was veering to the right (normally goes to left because of bush)
pulled over and whaddaya know! FLAT!!!!!
now the tyre that went flat while stationary was filled up left for a while and had no leak??? after i got it checked out.
the second is now ruined because the steel belt was driven on while flat. i filled it up and again seems ok.
now what i did to test that tyre is put water between the tyre and rim and check for bubbles, NOTHING!! on both sides.
so basically im thinking the tyres maybe faulty and just not sealing.
luckily i still have the reciept and going back on tuesday to talk to the guy that sold them to me and see what he has to say.
anyone else have similar experience???
https://www.sau.com.au/forums/topic/68493-nankang-tyres-possible-fault/
have always found nankang tyres to be fine
maybe u had someone play a prank on u at work
the other one i have no idea.....
thats what i was thinking but after the second flat, i thought it to be weird.
and with the car 100mm low and a flat tyre also, it wasnt a funny practical joke
the most common reason for a flat like that is the valve not being inserted correctly, causing a slow leak.
But back to the tyre place sounds like a good idea to me
took them back
there seemed to be no fault at all
if it was a valve what are the odds of 2 in a week?
anyway the guy sdaid understress it would normally be vlaves but he said its hard to get good metal ones
most are shit and leak
hmm I couldn't afford the tyres I wanted either so I got 2 nankangs on the back for blue slip (making it 4 nankangs on the car... 4 too many) - haven't noticed anything with em yet.
will keep an eye on them - good luck to ya let us know how it goes.
I had a set on my line for a while, and they seemed like any other low quality tyre, kinda sandshooish but legal.
Flogged them without mercy, never had any dramas other than a lack of smoke, grip and cred :)
Other then this problem how would you rate these tyres? for around 700 you can get 255/40/17's on back and 235/45/17 on front pretty cheap. Whats the grip like? do you think you could get anything else better then nankangs same size for around $700?
Cheers,
Paradizzle
How often are you guys checking your tyre pressures? Every car I have ever owned had sloooooowly decreasing tyre pressures, some worse than others. Brnad of tyres makes no difference they all leak something. I check mine once a week after I get them, then once a month if they haven't gone down noticeably after a few weeks.:cheers:
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
