World Record....?
Apparently the ultimate warrior is gay...that explans why you like him :D
Though, he never returned my fan mail as a kid so he musnt have been a patter ass:)
That is a brilliant result with the 2530s, congrats. Not knowing your tyre size it looks like the dyno run was stopped at about 7,800 - 8,000rpm. The setup seems to pull hard all the way to over 8,000rpm with the power figure not falling over.:)
Are you running a PFc? Are you able to give us an approximation of the difference in inlet temps between say 1bar and 1.7bar?
Congrats again, the car looks trick and has plenty of mumbo, shame its a drag car not a circuit car:)..................................................j/k
  • Replies 64
Don't you remember us Gav.....we are the ones who do cryogenic treatment. The run was to 8000...our redline is 9200. The rods and crank are stock and our diff ratios are too.
Yer - course I remember the "discussion" :D
The reson that I'm asking is that before I destroyed my recently rebuilt engine, I passed the traps on the quarter spot on 200km/h and the tacho was around 8500. Unfortunately I never got a chance to see what the GT-RS terbs could really do in anger, but I reckon I've got the right "ingredients" to chase your outstanding result.
BTW - looks like I'm gunna have another chance for that cryotreatment!
Guest two.06l
That is a brilliant result with the 2530s, congrats.  Not knowing your tyre size it looks like the dyno run was stopped at about 7,800 - 8,000rpm.  The setup seems to pull hard all the way to over 8,000rpm with the power figure not falling over.:D
Thanks Roy
you are right on the money with the 7800-8000 estimate
we are running power fc . An inlet temp comparison can't be given....but we used to run a thermocouple in the plenum, with only ever 4-6 degrees above ambient recorded.
Hey Roy, its a street car...................lol
Guest two.06l
What happened to the engine?
What was your MPH/ET?
Go the cyro buddy, for the price you'd be mad not to.
Just because you have the ingredients does not mean you can bake the cake.
Good luck with your build, and see you on the strip.
True that on the "ingredients". Will get there 'tho!
11.68 @ 124 mph, with what was a "conservative" tune on 17 psi boost and supposedly conservative timing. Just worked out why the tacho was out - was running MT slicks on the back!
Don't really want to go into what happened to the motor on public forum, water under the bridge with a Perth tuner
Guest two.06l
Yeah the reason why we built a new engine was due to a (and i use this term very loosely) tuner. We only use the best now, he might be expensive but its a hell of a lot cheaper than a rebuild.
Getting a cro-moly cage fitted tomorrow, as 10s are on the cards.
Paul, who is doing the cage for you? Care to pass on some details as I might know someone who might be needing one in the not to distant future.
One thing that really impresses me is the fat power band. Plenty of power and average HP is very high, not peaky like some dyno queens. Well done again.
Guest two.06l
A fellow by the name of Adam, Croydons put me on to him as he does all their work. when you need him let me know and ill pass your details onto him. Seen some of his work on the weekend and it is indeed "the sh1t".
Guest two.06l
Saw it out there on Friday and it looked fantastic! :D
What sort of fuel system do you run?
should have came and said hi, we run intank Bosch (swimmer pump 500hp) which feeds a 2 litre surge tank feeding two Bosch motorsport pumps (044). dual fuel lines connect to a TRUST twin entry fuel rail with SARD 720cc injectors. Then it is centre tapped to a SARD regulator feeding back to the surge tank. The whole system uses 3/8 braided lines with Earls connectors.
Guest two.06l
In this months hpi M-speed japan have a race car GTR runing 2.8lt with 2530s making 630ps or 636hp dosent say what fuel they are runing.
If its a race car id say its using race fuel not pump, spoke to Jim at Croydon's today and he's getting very excited about the cars potential for more! Like running 32psi instead of 27psi and better boost control and more fine tuning.
Guest two.06l
Mate whats Jims thoughts on pushing standard rods to this limit or past it?
Jims view is the rods are ok its the bolts and bearings as well as the clearances used. He has another car in the shop making over 500kw with stock rods. We break one it will be back to the ol' drawing board! Hope you haven't put the omen on us.
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
