Here's the deal... time to walk the walk.
Josh (Ruf 911 Porsche) Vs Fully Sick (Skyline)
Queensland Raceway.
Quickest Laptime wins.
We could have a cruise to QR if people are interested.... Would make for a very entertaining day...
That is if fully sick and josh have the nuggets to go ahead. The opportuinity is here. :D
https://www.sau.com.au/forums/topic/68649-showdown-2005-the-chat/
  • Replies 153
