do the same thing for approx 4-5 laps and then come back and say its working the same  :rofl:
And abo bob, isnt your turbo blown at the moment?
don't quite get your drift. :confused:
I said 12psi fine for the street. My boost spiked due to bad installation of AVC-R and this was on the track.
Yes my turbo is busted.
7 psi - 8 psi = stock boost.
I'm running .8/.9 bar on street, it's fine really.
It all depends on your luck guys, but to be safe MAX BOOST for our stock turbo is .8 bar which is 12 psi and I agree with Abo Bob :rofl:
Abo Bob should share his technique to get 13.8 with such a low mph :) Will you?
Erik
It all depends on your luck guys, but to be safe MAX BOOST for our stock turbo is .8 bar which is 12 psi and I agree with Abo Bob :)
Erik
standard is 14.1 ...so i dont know where your going with that ...?
:rofl:
if someone gives it a bit of stick on the street @ 12psi for a few mins... there will be sadness. Say your doing a mountain run or something.
short fast bursts is ok...
I don't believe a standard GTT can run 14.1 secs, that comes from my experience.
I run 14.8 with exhaust and filter , with an addition of 9/10 psi boost and safc2 I can run 13.9 so yeah.
I don't want to start anything :rofl: Peace
im sure it can run better than basically a 15
itll be driver.
and extra 2psi, and a fiddle with an saf-c will not gain you a whole second on the 1.4
  • 2 years later...
sorry to revive an old thread, but im looking to buy a R34, and a mate has a 99 wrx and he has been running 14 PSI on a stock turbo for a year now, yet i read R34 turbos blow up at 10 psi??
why is that?? also if you put a bigger turbo do you have to change anything else?? I want to run atleast 14 psi, so i can atleast match his wrx lol
wow this thread has been revived from like 3years ago, just thought id add in i ran 1 bar in my old rb20, full exaust, ca18det side mount (rb20 in a 180) and i didnt treat it very nice somtimes and it held up, so i think its just luck, but yeh if you dont want to test your luck then stay below 10psi
Simple = WRX turbos are not ceramic. :down:
Wanting to "run" 14psi is a silly thing mate, shows you need to learn a little bit more.
Different turbos flow more than others at a given psi. Wanting a turbo change "just" to run 14psi, silly.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
