Ok now i havnt trolled through a search to see if anyone else has suggested this yet, but i do remember a lot of people asking about this.
I was thinking about the nissan engine naming system the other night while a tad bored and this is what i've come up with, if anyone knows better please correct me.
Now as we all know the SR is a 4 cylinder alloy block, and the RB is an Iron 6.
Now the japanese word for "4" is "Si" and the jap for 6 is "Roku", to me this is a pretty obvious pointer. SR must mean "4 - somethingorother" and RB "6 - somethingelse".
Now can anyone tell me if there is a japanese word for Alloy or aluminium that begins with an R or a word for iron that starts with a B?
Any takers?
https://www.sau.com.au/forums/topic/68912-is-this-the-meaning-to-rb-and-sr/
  • Replies 40
japanese slang for alloy is "alu" if that helps.
something that dosen't sit right with that theory is the fact that FJ20's and CA18's are all 4 cylinders and they have different characters, same with the older L series straight 6's.
One of the guys suggested that R was for Rong (japanese dosen't have an L in katakana, hence Long is pronounced Rong) and S was for Short :) I think we threw something at him for that stroke of brilliance.
Good theory though, sounds a lot better than the nut-jobs that think RB stands for Race-bred.
cheers funky..... well the good news is that the FJ and CA thing doesnt go totally against what i've said.... but instead just throws any hope of consistency to use as a lead... bugger :)
I hope you threw something heavy at him :)
do we have any other takers with theories on these that ARENT "Race Bred" or related.
Guys I wouldn't waste too much time trying to figure out why Nissan used 'RB'26 or whatever... I noticed that most of the guys who do seem to think the Japanese people think in English, thereby we have numbskulls sayin "RB means 'race Bred' uleh!"... LOL as if the Japanese would do that.
But one little hint as to what they did mean, the R31 Skyline range included the '2.8D GT Passage D' which obviously was powered by the 'RD28' diesel engine. So if we look at that designation, the 'D' in 'RD28' means diesel of course... obviously... nothing groundbreaking there. Hmmm, I'd go as far to say that the first letter ie: 'R' in 'RB26' is just a letter used to signify a petrol inline six.
its like asking what is 'pH' stands for?!
pH? why that stands for pH = -log10[H+] which is the "hydrogen ion exponent" and the designation PH for the numerical value of the exponents of this power.
[H+] indicates the activity of H+ ions (also written [H3O+], the equivalent hydronium ions), measured in moles per litre (also known as molarity).
why do u ask? :rofl:
maybe you should have trolled through search..
you would have found this..
R = 6 cylinder, closed deck.
B = Gasoline application using cast iron/nickle based block.
S = 4 cylinder, closed deck.
R= Gasoline application using sand-cast alloy based block.
K = 4 cylinder, closed deck.
A = Gaslone application using sand-cast iron based block.
Q = 4 cylinder, open deck.
R = Gaslone applcation using die-cast alloy based block.
nah the RB26 is a RB26
yeh im not trying to say they are the same engine but they are built the same just with 2 cyl + or -. Solid lifters and all that jazz. Plus whats 18x1.5?? thats right. 2.6 and change. Testament to the fact that my ca ownz :rofl:
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
