600hp: 367awkw is impressive from those turbos! I have always thought they were capable of an output up in that range. But never had any proof until now. I think that is definately enough power to run a 10.
Cefiro_PWA: For a comparison, when I first got my car I ran an 11.99 @115.4 mph with:
Stock turbos and dumps, 3" inch front pipes and cat back
trust pod filters
trust intercooler
17 psi boost
Jap chipped ECU
217rwkw
Then I added a PFC, Z32 afm's and cam gears and it made 273rwkw. On a very hot day when noticeably down on power (intake temp at 66 deg) I ran an 11.6 @ 118 mph. This was still far from the potential of the car.
There are many GTR's up here with heaps more power but getting worse times. Just goes to show that there is more to it than peak power outputs.
  • Replies 96
trust pod filters
trust intercooler
17 psi boost
Jap chipped ECU
217rwkw
nice work wish i could get a GTR i wanna have a go and just getting inthe low 12s
Welll, I am just here to say something...
My fren has a std GTR.. He ran constant 11.94 @ 114/113MPH.
3" front , stock Dump pipe. 4" cat back.
Blitz Twin Entry Intercooler
ARC Airbox
17psi boost.
255 street tyres on 18" rims.
With wider tyres say 275 he will get better traction.. but there expensive:)
Which is why i think that time of 11.7 is not impressive. Mind you its still got std ecu.
He is going to get Power FC and a custom dump pipe setup with intercooler water spray, he is aiming for 11.7 @ 116mph.
Will keep youse up to date.
If that car is running stock turbines, it won't be running anything for very long at 17PSI...
  • 2 months later...
tick tick tick doom and when i goes it will take the motor with it, i have seen 3 of these in the last year. And it's funny how these guys come out of the wood work "my mates car"
there is a big difference in this range
at 316awhp i ran 12.0 1/4mile
at 520rwhp i ran 11.3 1/4mile
so to run a 12.0 or 11.9 in gtr is not rocket science
but to get in to the mid or low 11's takes a lot more work (lot more)
Well.. it can't "take the motor with it" because its simply only 17psi!
Ive seen 11.6 in a GTR in japan ( R33 GTR S1 ), They said it was running pump fuel ( 100RON ) and street tyre's! ( not sure what kind ).. this was only @ 1.2kg/cm2!
so around 17pounds!
just look's like half of your car's are shitty and low on compression.
so around 17pounds!
YES it can and very offen does as the exploding cermic wheel spend bit everywhere including back into the combustion chamber making and almightly mess of thing ,this is why people throw the std turbo asap as its cheap to replace just turbos than a motor and turbos. The std turbos are a ticking time bomb if run anything over std boost (some may last a little or alot but they all fail in the end)
exhaust wheels are ceramic, the intake shaft is fine on the standard gtr
why would it suck inside, its an exhaust wheel... "ExHAUST" get it? exhaust?
it just comes outto the cat
only thing youd be damaging on the standard turbo's running 17psi is the turbine wheels..
anyway who cares... 11.6 is fast.
look i have seen three rb26 motor damaged in the last 12 to 18 months by this NO if but or maybe
It happen offen i didnt believe until i saw it then another and another
Don't believe me if you like your MATE may pay a very big price for it
I surgest you talk to some other tuners etc that have had experience with running std gtr hard and you will find the FIRST thing they will tell you to lose the std turbos before they fail.
pnblight is right, I have heard of many stories of turbine wheels calling it a day and ending up in the sump....
CEFIRO_PWA - In most cases the exhaust wheel ends up in the cat, but the front wheel can go the other way!!!
P.S pnblight, I have a surprise for you, stay tuned!!!!
Please do tell i am every the ear to good story Man how does not listen is a fool? as i know as much as anyone, to listen as you can learn a from those who how have been there in the past.
please do tell jagr33 ,
pete
Tell your mate to either back to boost off to under 1 bar or get rid of the stock ceramic turbos . Its only a matter of time before they let go and guess what the engine will be full of ceramic dust , a sand like material that will score the bore and may bent a valve or two .
There is nothing wrong with the stock turbos and yea you can get plenty of power out of them . The reason people change them is the CERAMIC wheel s let go and damage the engine in most cases .
I dont blame you for not understanding how it happens but believe me it DOES i have seen several engines go when they spit the turbos .
The first thing i did on my 34 is replace the turbos with gtss's . The stock turbos are not much smaller and they spool up earlier but i can take the risk of destroying an almost new engine .
hey Jerry, how is it all going???? Im off to BEL 2moro to add a few goodies, and then it will need a dyno tune once I get back from work on the 10th....
Its all good with me , heading to wsid on wednesday , weather permiting to put bens tune to the test .
What are you doing to it now ?
What dyno are you taking it to ?
I will put mine on the dyno as well but i only trust one Dyno and thats in south coast .
I think Paul ( ozgtr02v) wants to put his 34 r on the same dyno so we can compare the 2 cars .
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
