I've thought about this too, and I reckon that a turbo is most likely to blow as you lift off to shift gears. think about this, you are on full throttle, 6500rpm in 3rd, turbo is making 1.1bar boost, as you lift off, there is temporarily a restriction in front of the compressor (before the bovs react) that trys to slow down the compressor and by extension the exhaust wheel, but at this moment there is a huge amount of exhaust gas trying to still make boost.
all theory though :D
but I agree, someone should call myth busters.
Your theory doesnt sound too bad... when mine let go, I was giving it a flogging (as you do) and it was running fine. Lifted off the throttle for a second and then when i went back on the throttle there was no power and it was belching white smoke. Until I lifted off the throttle it was running fine...
I thought the lifting of the throttle when the turbo popped was the reason it was sucking back also... but think about it. Human reactions are just not that fast, by the time you heard that noise how many times would the turbo have spun..
We had tried this theory and kept the foot down when we had a turbo blow.. made no difference. 3 cylinders completely scored and ceramic in the oil system etc..
I have seen it happen to at least 6 GTR's though and a couple of GTS-T's..
It is still very rare.. maybe down here there are more people on a budget trying to push there stock GTR's as hard as they can and thats why we see more blown stockers? (11.6 with stock turbos and fuel system :( )
As someone else said though, the exhaust pulses, and being split this is made worse. The time is only very small.. but i'm sure if someone really good a physics worked out all that was going on in there at the time (had to get the data as testing would be hard) The turbo is obviously spinning at many times faster than the engine is turning over.. the explosion from the exhaust wheel must be very powerful is my only guess.
I wish I had more proof or an explanation instead of looking like a madman who makes up myth's.
I will take some detailed photo's next time.. some might try and say it was really bad detonation in 3 cylinders, as some engine builders have said. haha.
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
