Hey Guys, Unfortunately due to family circumstances it looks like im going to have to pass ownership of the goblin onto someone else. Price updated! I'm looking for 23K NEGOTIABLE
I've found something that has family approval on it so i'm looking to move the goblin very soon.
1997 Jungle Green S14a Body has 190,000kms on it, engine has 8500 since rebuild.
Specs are as follows:
Engine - Internal
New S15 engine
JE forged pistons with gapless rings
Balanced, shotpeened, linished crank and rods
ARP head studs
Tomei metal head gasket
HKS Step 2 256in 264ex 11.5 lift cams
Trust valvesprings
HKS rocker arm stoppers
HKS vernier gears
Engine - External
HKS GT-RS turbo
Custom steampipe manifold, coated
Hybrid FMIC
CES Dump (custom with larger wastegate pipe)
Fujitsubo catback
Z32 Maf
DE throttlebody (60mm)
Apexi pod
Cusco catchcan
Splitfire coils
Chiptorque daughterboard
Greddy Profec B boost controller
Apexi 740cc injectors
HKS fuel reg
Bosch fuel pump
Oil Cooler
32mm radiator
Nismo engine and gearbox mounts
Trust Sump Extension
Driveline
Cusco RS diff
C's short shifter
Suspension
Tein HA coilovers - adjustable pillowball tops
Tein adjustable radius (tension) rods - pillowball
Cusco lower arm brace
Roadholder front strutbrace
Cusco rear strutbrace
Whiteline adjustable front swaybar
Roadholder rear swaybar
Pineapples
Every bush replaced
Wheels/Brakes
Advan 17*8 17*9 rims
Azenis ST115 tyres, 235/40 front
Toyo Proxes T1-S 255/40 rear (brand new)
Brembo front calipers (R33 GTR)
Project Mu alloy hat 2 piece disks (front)
Z32 master cylinder
Cusco master cylinder stopper
R32 GTR rear calipers - seals were rebuilt 1500kms ago.
Other stuff
Nismo rear wing
Cusco 4 point cage (bolt in so can be removed if you don't want it)
SPA gauges - oil temp and pressure, water temp and inlet temp
Bride Zeta 3 bucket seat.
It's just got 12 months rego on it and has copped 2 services in the small time that i've owned it. I've only been able to put 4500kms on it in this time so the engine is basically 8500kms old. It's made 240kw@wheels in current tune but depending on how you want to set the cams up there's another 10-20kw@wheels in it if you dial it in for top end power rather than response. I'm basically looking for mid 20's or so but can be negotiable depending on a few things. If anyone is looking for a track car, or wants something very well sorted and quick on the track this could well be it! It's been seam welded in the lovely spot between the front guard and the door that 200sx's love to come apart to increase chassis rigidity.
This thing is just so easy to drive quickly on the track as was evidence of my first time out at wakefield with no previous experience, pulling off a 1:15 in the wet on low boost.
I can be contacted via pm or by email to
[email protected] .
Cheers,
Luke
https://www.sau.com.au/forums/topic/69099-fs-97-s14a-highly-modified/
still for sale people. Sad news is that Luke has been in hospital due to a broken ankle but will be home by weeks end.... anyone that may be interested is still welcome to come check it out :D:D:D
price - I know last time i spoke with Luke he was looking at offers around the mid $20k. Luke can confirm this when he gets home later this week....
Pics - i am sure Luke has some he can send you when at a computer
Hey Guys there's a few things that need to be taken into consideration now after i've broken my ankle and are unable to do a few things i would've liked before sale.
It needs a wheel alignment, the CES dump pipe needs to go back in as it's got a trust dump pipe at the moment... not that there is much difference really. It's about 2-3 kw up top and a little bit down low. Other than that it just needs a front bar as always due to it being "kangaroo modified" by the previous owner. I'm willing to take this into consideration on the price obviously. As i said i was looking for mid 20's but i can be negotiable, please make an offer if you are interested as due to my ankle it's just a garage queen now.
pics can be found here
http://photobucket.com/albums/y106/whoneedstherapy/
Hey Guys,
Price has been updated for one of the better setup 200sx's in the country. If your looking for a track weapon this is definitely a car to consider. If it wasn't for certain family issue's and a shattered ankle there is no way i'd sell it.
Cheers,
Luke
Must be sold, i have something else lined up to suit my crippled needs!!
Come on guys, someone must want an extremely well setup 200sx
It has a whole jap spec series 1 rear end on it. You'll notice that the rear bumper doesn't have any reflectors in it, nor does the bootlid have a brake light in it either. It is however a 1997 model series 2
  • 3 months later...
i dont know. guess its not for me then. good luck with the sale though.
hey guys,
This thing has to go as i'm moving out. Slight changes are now there's a power fc in there, making 245kw@wheels @ 20psi. Also it has 17x7 & 17x8 Avs model 6's on there in gold as well as a set of 18x9 & 18x10.5 SSR Sp1's that can come with it
Asking 23K negotiable
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
    • @Stringycheese  Have you only gone to the one blue slip workshop?  There will be a heap of them where ever you live, good odds that the next place you go to will pass the car.  Unfortunately (or fortunately?) every blue slip / engineering workshop will be different and will be happy passing or failing different things - despite working from the same set of rules. It's kinda like 2 lawyers arguing over a piece of legislation, each saying their interpretation is correct. Might seem strange that this happens when it comes to getting a modified car passed, but this is very much a thing. A big part of the game is finding an engineer / workshop that is on the same page as you.
    • Bah. I daily mine. ~60km per work day, 10-12 thousand km per year. What's the point of having a dirty old Datto and leaving it in the shed. It needs to be driven and enjoyed while the govco allows us to do so. It will only be a few years before we're forbidden to even start up internal combustion engines.
    • Judging by that spring perch and the normal looking spring on it - not a coilover. Well.... it is a coilover, just a stock format coilover, rather than what everyone calls a coilover.
    • Yes it is. We get stock from Nismo directly. I'm happy to take photos/video of it as proof before I ship it with timestamps or whathaveyou.
