lifespan of a cat is about 5 years, after that they become useless.. and can actually impede flow.
Sure, they might *look* fine, but the honeycomb material is involved in a chemical reaction in converting the CO (and whatever other chemicals it is engineered to attract).. once its spent, no more cat reaction = cat useless..
yeah, so then you come to me and say "hey Dan, can you buy me one of those super dooper cat's from your work for $170?"
And I say sure...no problems.
You could go the ultra high flow cats which are now available. They are around $240 and flow an extra 40% or so. They are a much larger body though so you have to be aware of space for it.
You forgot Step 6. Get pulled over by transport inspectors who tell you your cat is hollow because of the poisonous gases bellowing out the back
and Step 7. Get fined up to $5000 depending on how 'aware' you were that it was hollow.
If you have the cat casing still on, but just hollow, you can only be fined for emissions...
I know a guy with a hollowed cat, you cant see the gasses coming out, it has to be taken to an inspection station for a test to concluded that, even then see above.
and the fine is on a per cylinder basis AFAIK.
:D for a uselesspost.
Back on topic: The gain from a highflow cat would be VERY minimal maybe 3rwkw max...
haha. They can actually do a gas analysis on the side of the road. And with one of those, you can tell if there is no material in the cat. Your Nitrous Oxides would be through the roof. And as for that, once they find that your cat is hollow....coz any idiot can tell the difference with an analyser, you get a machinery and they fine you. The fine is up to $5000 depending on your involvement.
Thankyou for wasting my time for having to explain it. ;)
put your hands around your neck and squeeze tight, now try and breath out....
same thing in your exhaust, you totally have defeated the purpose to having a highflowing exhaust, especially if you have the original cat which is more than likley blocked having had a high fuel load dumped into it over the years as well as heat which is associated with running more boost.
mine the front side of it melted and was practicly completly blocked when i last replaced it.
also if your planning on gutting a cat just bear in mind that the contents of the honeycomb is reportedly carsonogenic (sp?) (that said you can get cancer from scratching your armpit these days so why worry eh?)
i got my replacement cat from batmbl as well, he was very good to deal with.
as gordon said before, after 5 or so years they are useless, the fronts become melted and blocked and the honeycomb is no longer effective, replacing it with something capable of flowing more and converting more gas is a much better investment than replacing it with another stocker
Im not exactly sure what size my cat-back exhaust is... the previous owner told me the spec of it but i forgot... what i do remember is that its bigger than 3 inches... its either 3.25" or 3.5"...
Now the question is, will have to find a cat with the same size ends? Or will standarad 3" hiflow cat do the job? I just dont wanna end up buying a cat that doesnt fit, or even worse, going to a muffler joint to get them to measure it and find out after paying them $$$ that it would have fitted!
The intuitive response would be that the same size cat would be required but im asking bcoz currently with the cat back exhaust, the bigger exhaust pipe is attached to the smaller stock cat... If you get what i mean...
Also, is it possible to put your car up on a jack and replace the cat yourself with some backyard tools? Is it a complicated process?
Anyway, any help much appreciated!
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
