jsut wondering if anyone can tell me the differences between the R33 N/A and the Turbo. aiside from the fact one has a turbo and intercooler etc to run the turbo. do they have same brake discs, etc. also inside are they exactly the same essentially. panels and everything outside is the same aswell?
cheers. Mark
https://www.sau.com.au/forums/topic/69304-na-turbo-differences/
well stronger internals, stronger gear box, lower compression clutch plate also superior, also the brakes are alot better. i dont think the interior would be much different. but apart from all that
the GT badges are red and white for turbo and green and white for non turbo :)
brakes definately are different... (unsure about gts4)
GTST: 4pot front, twin pot rears - with the NISSAN on the calipers.
GTS: ugly black things :( I dunno what they are - will let you guys know when i do the brake upgrade.
my gts has red gt badges (type-s standard)
and DaGr81 is fairly correct with the other stuff ^^^
Obvious one - tacho assy is different due to no boost gauge......
Yup, red/white badges for Type S NA's, blue/white for non-type S.
Front brakes have 2 pot calipers, rear is single pot for NA, I think the master cylinder is different as well due to the different pot volume. R33 GTS4 uses the same brake setup as the GTS/GTS25.
mines type S and has blue/white badges
lots of topics on this - use the search mate :D
basically:
brakes are better on GTSt
internals are stronger on GTSt
gearbox is stronger on GTSt
better injectors on GTSt
dash is slightly different
wheel hub is 4 stud on NA and 5 stud for GTSt
different exhaust setup due to turbo on GTSt
different ECU
better stock clutch in GTSt
thats about it i think i may have missed somehting though
Non turbo has 4 wheel studs per wheel compared to 5 on the turbo standard rims on turbo are 16" and 15" on non turbo, brakes are a definite difference, just did mine but they are ABS. Final drive ratio (diff) is also different marginally and not always LSD on N/A, the gear box I'm not sure as mine has the same number on the manaufacture plate as a turbo model. Both have HiCas.
Bah, just when I thought I'd got that one figured out.... I'll fall back to my previous theory then - red badge = sold thru Nissan red stage dealer, blue = blue stage dealer. From what a friend in Japan has told me red stage = performance stuff and blue stage = family/smaller car stuff.
hmm... mine is an NA and has red and white GT badges... also has RB25DET sticker under bonnet..... but is def NA
What does it say on the VIN plate - RB25DET or RB25DE? Where is the sticker you refer to?
mines blue and it aint exactly a family car?
Err, by family car I meant they sell cars like the Maxima, Sunny, Pulsar etc as well, I guess the NA Skylines are the top of the 'family friendly' cars?
I've got blue badges...but my car was sold by the Prince Nissan Dealership?????
I'm not sure where the Prince dealership chains fit with the Blue stage/Red stage thing.
Anyway, tis just a theory....
it could just be a possibility that the previous owner did not like the red badges and
threw on the blue to be more realistic...
blue badges are quite cool though - very rare.
Tehehe, in NZ blue badges on R33's are common as dirt, probably because there seem to be a heap of 2L GTS models around at the moment, they out-number the GTS25T's by probably 3 to 1! And GTS25's by about 100 to 1....
Yeah I prefer the blue, considering my car is blue as well it's looks good :cheers:
I used to get people staring at it funny though, cause I had blue badges, N/A exhaust, no gauges, yet they could hear the turbo :)...the Big front mount gives it away now though.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
