Here is my situation,
I have an R32 GTS-T Currently running the following:
RB20DET (Internally Standard)
Microtech Computer
Profec B Boost Control
GTR Injectors
500hp Fuel Pump and Fuel Reg
FMIC
GT-28 w/gti-r exhaust housing
Exhaust and all the normal stuff
My engine is healthy as far as i know and am wondering how my RB20 would push a turbo of this size. Obviously i would have to high mount the turbo and prolly flow the heads a bit, but does anyone know how this would drive or how to make it more driveable? Its just i have a guy with a new T70 thats too big for his car and he wants to swap me....
Any help would be good, ppl with this setup would be unreal.
Thanks,
Matt
https://www.sau.com.au/forums/topic/69307-t70-turbo-onto-rb20det/
They are about a 800-850 hp turbo, so on a std RB20 with std g'box i think you will find you will be struggling to make any power with the thing.
RB20s can handle decent sized turbos whilst still being reasonably responsive. Depending on what you want from the car and what you can afford, id say get a 2835, or even a 3037 with a small exhaust housing if you want to be a little more adventurous on the std bottom end:)
Can i ask what power you are making with the GT28, any specs on the turbo?
LOL...thats cool, and easy to fix.
What size tyres do you have? For example if your rears are 235/45/17s, and your run was in 3rd gear then...
3,500rpm , 73km/h
4,000rpm , 83km/h
4,500rpm , 93km/h
5,000rpm , 103km/h
5,500rpm , 113km/h
6,000rpm , 124km/h
6,500rpm , 134km/h
7,000rpm , 145km/h
7,500rpm , 155km/h
So assuming you are running 17" wheels, then thats roughly 14psi @ approx 5200rpm?!?!?! Seat of the pants does that sound about right?
If your running 16" or 18" wheels these speeds will be different:(
Dude, it will work fine. Just your going to be spending more on brakes :( You gota get that sucka to spool somehow. Best way, STAND and I do mean STAND on the brakes and the go go pedal at the same time should make boost :(
But, I do think its too big unless your going to go crazy on set up to get it to come on boost.
Would the T70 even make decent boost (1bar) before 7000rpm on the rb20???
Serious question, not buggering around. :(
Maybe... Serious tho 3rd gear, stand on the brakes, it works.
My mates gemini with effectivly a t60 on it, and its a 2L 6cyl, if he stands on both pedals, it makes about 20psi by 4000rpm :( Wont make anymore, the brakes let go after that. Its funny as.
Depends what T70 we are talking about? The Ebay one? Or a somthing else?
My mates ca18det with the ebay T70 kit is making 260rwhp @ around the 7000rpm mark with 1bar. So one would asume a rb20det is up to the task.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
