Gday all,
A real quickie here, just wondering if anyone knows what power an RB20DET, pref out of an R32 GTST, makes at the wheels - when she's completely STOCK STANDARD...
I've just the below mods done to my baby and she now puts out a tidy 166.3 rwkw running 1.0 bar boost. :(
Apexi power FC
Greddy Profec B elec boost cont.
3" turbo back exhaust (catco hi-flo cat & dump pipe, X-force cannon muffler)
600x300x76 FMIC with full custom plumbing
HKS pod filter in FL guard - best cold air intake i've ever seen!
Sard adj fuel pressure regulator
Walbro 550hp 250 lph in-tank fuel pump
stock injectors - about 80% duty cycle i think...
Unfortunatley I didn't get the chance to dyno it beforehand so i'm interested to find out what the power difference is. I'm guestimating they make around 100 - 110 rwkw but if anyone's actually dynoed a stocker, i'd love to here what they really make!
Cheers
https://www.sau.com.au/forums/topic/69509-atw-power-for-a-stock-rb20det/
Why such low power figures?
Is your car 1989, or does it have a series 1 rb20 in it??
Those mods should see atleast 180rwkw, if not more...
Stock standard ive seen one dyno at 104rwkw to help you out!
Yeah the bloke at Unique Auto Sports says those mods should see 170 - 180 rwkw, but then he said that i am only running 14psi plus its a stock turbo...hmmm. I've got to back and see him for a few tuning tweaks and i need to double check the injectors so i'll see if there's any difference then...
104rwkw - cheers!
Ye... you could run 1 bar (0.7psi more) but wud of thought u wud of got more.
Maybe u have a series 1 turbo, these are a fair bit weaker and have different inlet manifolds too!
No stress... bigger turbo time :( Esp with those supportin mods!
Why would you have thought he would make more power?
As for different manifolds and differences in turbos, Series I and Seies II R32s :confused:
From what i would have gathered, 166rwkws is on the money:)
Meant engines dude! Not the actual car... lol
From what ive seen those mods WITHOUT a power FC can make up to 250rwhp... hes got that ontop..
Im yet to see a std turbo R32 GTST make 250rwhp, big thing with the Pfc is that the power curve/tractability of the engine should be improved...the turbo can only flow what it can flow, but the Pfc can help improve mixtures and response.
Another thing, i dont know how true this is as its just an observation, but the R32 ECUs appear to be far more flexible then the later R33s which insist on doing silly things with fuelling and ignition when you wind up the boost with a few breathing mods.
The R32 on the other hand does a pretty good job of adjusting to the new airflow requirements of the engine....
lol...That said, does the car drive any different with the tuned PFC now:)
Bigger turbo time = nothing makes me more moist!!!! :aroused:
in time an HKS GT RS will grace my exhaust manifold...
mines a 1992 build so its definitely a series 2 engine & turbo...very odd that the power figures are less than what others are gettin with similar / less mods
also i am running quite wide rear wheels & tyres - 9" wheels, 255 tyres - would that affect dyno figures?
No stress... bigger turbo time :P Esp with those supportin mods!
I had mine when it was bog stock standard on 2 different dyno dynamic dyno's.
D&T Performance - 113rwkw (hot day 98RON BP Ultimate)
RPM Performance - 115rwkw (cool day, 95RON BP Premium)
Check out some of the dyno run scans on the D&T Performance website.
It gives you an idea how the stocker rb compares to the ls1's, 200sx's etc.
I later had mine on the RPM Performance dyno, ran 1bar with a FMIC, 3" Turbo back exhaust, a little bit of extra ignition timing and fuel leaned out slightly via fuel reg modification. It made 164rwkw.
A turbo can only flow so much air before it begins dropping efficiency.
This is why RB20 turbo's tend to drop boost UNLESS you run a good ebc that can vary the duty cycle at higher rpm. (AVCR or Blitz SBC-ID)
With 1bar holding to the redline it should be up around 170rwkw, and maaaybe 175rwkw if its a cool day. It all depends on the tune, how rich it is running and how agressive the tune is (ignition timing)
this is strange my car with front mount. 12PSI and zaust has 141 KW at the wheels. i am sure u should get more then 166KW. maybe something worng with his dyno. The Power FC should atleast give u 20 - 30 KW on its own
i just wish ppl would stop comparing their dyno results to someone who has dyno'd their car on a different dyno in a different state. workshops can make a dyno read as high or low as they want it to. run it down the strip, at least that gives you a better indication of how quick your car is imo.
    • Mixing things up - installed some leather recaros to match the leather seat covered rear seats. Interior looks pretty schmick now except for some slight wear on the steering wheel which I will monitor and address if it becomes worse or actually noticeable!
    • Didnt realise RB's had more then 1 head.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
