Chris,
Maybe you can try Dave Forrester Fine Detailing. He is at Unit 9/24 Hooker Street Islington. 0419439795. Ring him up and get a quote, but I think its roughly $110 for wash/buff/carpet clean and good overall tidy up. I've seen his work and it is pretty good value for money.
If you have small paint scratches/blemishes/dents, ring Colour Mechanix on 0412213990. They do very good touch up work if need be.
Guest DIRTgarage
Anyone know any decent car detailers in Newcastle?
I am after paint/engine bay mostly, Intereior a bonus.
Cheers
Chris
We use Baywash, they are here in Nelson Bay.
If you saw our car on the Drag Combat stand at last years Autosalon, or in issue 25 of the magazine you will know why. He is about $300 for a full job but spends 1/2 day on the car. Worth the $$ IMHO.
Hi Paul, Im trying to give my place a free plug here. We spend the full day and are a bit cheaper than that. You should give us a try. We own skylines and have had plenty of showy cars in the past. Have done cars for a few people off here. Probably would be a big ask to get yours any cleaner though! Cheers Darren.
Guest DIRTgarage
sorry didn't recognise you in the suit...j/k
two blokes....5hrs...plus paint protection...$300
= bargain
but....ive seen your work and would recommend that anyone living in Newy to see you.
How big a chunk are we talking Dave?
and where abouts on your bar?
Cause fibergalssing isn;t that hard, and you can get repair kits that are fairly inexpensive.
I've cracked my 400R bar and I'm gunna fix that myself.
Well, myself and some of my friends who will rpob just stand around, talk and order the pizza :headspin:
eXc, how come you are getting the car detailed dude?
I only just had it imported, and I thought I'd get it cleaned and buffed proffesionally, then I can just maintain it. Like I tried to clean it up, but I just can't get it the way I want it, so I figure for a bit of money I would.
I have decided to use a guy that was reccomened by a spray painter that I totally trust. He is gonna do it for $150 which is everything BUT a polish/buff. I am gonna have a go at that myself, if not, the spray painter I know will do it for $200ish...Works out to $350 all up and I think it's worth it, I have seen the painter's work and he is really good.
The detailer doesn't want me giving out his details tho. He no longer does it for a bussiness, he is doing it as a favor for the spray painter.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
