The japs have a weird way of thinking lol
Just wondering has anyone ever come across an issue when the outter tail lights only work when the headlights are on but all lights come on when the brakes are engaged? It's obviously intentional. I checked the globes, they were fine and were twin filament and the wiring around the tail light seemed ok. Has anyone ever come across something like this and where they could possible trip the wire so that they only come on when braking?
Cheers,
https://www.sau.com.au/forums/topic/69821-inner-tail-lights-nw/
inner taillights were single globe sockets when i first got my car from japan and fitted twin filiments sockets and changed around some wires,and now all four taillights work when parkers are on and when i brake they go brighter..r33 series1
may pay too have a look to see if urs are the same....
Mr fanny i think your right,cos on my compliance sheet it says that the did somework on rear taillights.they changed inner tailight sockets to single filiment,and you cant just put in a double filiment globe cos it wont work,u need to change the inner tailight socket to double filiment.Any jap spare parts should have em.dont try autobahn or repco as ive been there with no luck..
Welcome to the "silly little things" in the ADR's. All the the Aust delivered GTR's got the same treatment. Look at the tailights on the next ladder-chassis 4x4 you see.
Funny, my car managed to slip past without getting the 'snip' :D
Funny, my car managed to slip past without getting the 'snip' :rofl:
It's not a big deal, but the Aust GTR's had that because the outer lights are the indicators. The JDM indicators became the reversing lights, and the JDM reversing lights were turfed so that the wide Aus licence plates can fit. It's one way to tell an Aus car from a Jap one - there are no lights around the number plate.
Mark
You mean like this?
Hah my ones werent cut, just had a little piece of tape over one of the inner globes so they wouldnt light up when i pushed the brakes, and all 4 were on when i had the parker lights on. My one didnt get snipped either :rofl: Just got rid of the tape now all 4 work when i push the brakes :)
  • 1 year later...
my inner tail lights dont work but they all light up when i brake
wat do i have to do to fix this?...im pretty sure the globes are working fine.... its twin filiment
also some wires have been cut and wrapped around other ones with electrical tape...not sure wat has been done
Edited by skyline17
  • 3 weeks later...
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
