... i havn't really practice launch....ect but had a bit of play around with a 2004STI with the work on it and i just couldn't launch my Gtr right, only when we do a rolling start i was about 4 cars length in front but thats not important. I just want to learn how to launch my car right so when i hit calder i could have a good time.
Advices need please :)
https://www.sau.com.au/forums/topic/69825-how-to-launch-a-gtr-right/
  • Replies 96
Take it to the track and practice. Much easier to learn when you have a proper prep'd track and a timeslip to gauge your efforts.
Start low, build up until you either break something or wheelspin and then go with what works best.
exactly what r32boys said......get it above 7000rpm and dont ride it, just release the clutch! if you go too low (rpm) then it will just bog and you will get flogged off the line. Hope you have a decent clutch though!
Yes i tried anything under 6000rpm and it just Bog down big time. I have after market clutch and i did try to ride the clutch and i've burnt a bit off it, dumb me.
I'm so used to RWD car, launch about 4,5000rpm and never bog down. Is it that easy to break something in a GTR by launching it at 7k?
I've done plenty of launches - only broke a gearbox so far, pretty sure that wasn't because of launching, it was 3rd gear.
If you want half launch i find you can get off the line quick even if your only on about 5000rpm, but you've gotta slip the clutch a little, but you'll need a strongish clutch for that, std one will just slip i think. But yeah you can launch at 7-8k as well, but i find just steping off the clutch doesn't work as well as easing it out.
What you mean by half launch? At which ...rpm? See you at Winton :)
Dumping the clutch or side stepping it will break driveshafts, stuff uni's and stuff your clutch center... If you watch all the japs how they do it is the nicest possible way for the best result.
Pull your handbrake on and leave your hand on it pulled up bring the revs to around 6.5+ and pull the clutch out till you can feel the car fighting the handbrake, from here release the handbrake and clutch at the same time and your away.... SOunds hard but by doing this the clutch is already semi engaged and nearly up to speed and all the slack has been taken from all your driveline components. Sure it burns the clutch a little but its no worse than any other method!!!!
What you mean by half launch? At which ...rpm? See you at Winton  :rofl:
Half launch .. dunno how to explain it, getting off the line without bogging down big time, but without launching full on... around 4000rpm and slowly rising the rpm as im slipping the clutch out. I've got a twin plate so its pretty strong compared to a stock clutch... I don't do it that often, as the others have said i'm sure it willbe burning it out doing that... but i found just stepping off the clutch felt to harsh on the car and just didn't feel as smooth.
Not sure if i'll be at Winton (not racing, might come for a watch) if i do, i'll take you for a quick drive to see if i can show you how i launch.
Same here, not too sure now as i havn't found a proper set of rims for GTR, i'm running 17/8,5 and 17/9,5 so car handle a bit wierd for a 32Gtr also my Tein is wearing out a bit as well.
yeah i think i know what you mean by a half launch but i think my heavy duty clutch won't hold it as well as your twin plates therefor it will BOG down.
Good timeslips in a GTR comes at the expense of wear and tear - literally!
Decide if you have the spare cash for clutches, gearboxes, driveshafts or diffs before you try those rev limiter launches.
That said, a hell hard launch even in a near std R is bloody good fun!!
Werd! 4 Clutches and 2 Gearboxes say you're right.
This is the best method, and the one i use. It does take a little getting used to co-ordinating the right actions.
Just dialing up and dumping places too much shock on ALL the driveline components. Basically the handbrake method loads up the drivetrain and puts less stress on the components. Sure it is at the expense of clutch wear, but i would rather put new plates on my clutch than replace a gear in my dog box, or a drive shaft.
Basically there will always be some wear and tear with ANY method of drag racing. Its just up to you which part you want to replace sooner.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
