  • Replies 60
By the way...what's a sporty family car I can buy, It might come down to that if my wife gets her way LOL
Andrew
STAGEA!!!!! Basically a R33/34 4wd station wagon, powered by a RB25DET. :) You could even use all your "goodies" for this car.
There is one or two in the for sale car section.
Here is one:
http://www.skylinesaustralia.com/forums/sh...034#post1298034
:bahaha:  thats funny as hell man
You dont have a decent electronic boost controller stashed in there do you?
I'll have a look I'm sure i got an ebc but i just got to look for it hehehe
Andrew
STAGEA!!!!!  Basically a R33/34 4wd station wagon, powered by a RB25DET. :P  You could even use all your "goodies" for this car.
Here is one:
Hmm...not bad. The one for sale, is that a cheap price though? I was looking at perhaps getting a subaru forrester or a ford territory lol. Hence me selling these bits.
PS. Do the following items fetch much at all? Not too sure. They are all in pretty good nick.
AFM
front and rear hubs
cf bonnet, i know they fetch a bit new but what about second hand?
tein coilovers
Thanks for all your help people
much appreciated.
ANDREW
Hi Hus
please look at the wanted to buy thread. What was your number again, will give you a call.
Andrew
My number is 0422 304 918, Thanks.
Is the CF bonnet for series 1/2 ?
Is it damaged in any way?
What does it look like? Does it have vents etc?
Do you have any pics? Pics to [email protected] if you do
CF Bonnet is for series 1
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
